I say again: the suspension is in.
Thanks to all on Stangnet.com who gave advice. (And thanks to 3 buds who spent an entire Saturday helping...we started at about ten AM and finished by 6:30 PM.)
Details, if anyone's interested:
Did the M+ kit with 620# drop springs, 1" front sway bar, new struts...rear was 4.5 leaf mid-mount eyes and new shocks. Poly bushing throughout. I have the rear sway bar, but couldn't do it because it was getting late.
All I have to say is wow, what an easy mod, and what a difference! Firm, but no harshess at all, but also no bounce. "confident and sporty" is a good way to describe it. It corners perfectly flat, with immediate turn in & out of corners. My loose steering is now much improved, interestingly enough. (I have the M+ "make it new" kit which I still need to install, but want to get a feel for the suspension first.)
The only difficulty was removing the rear leaf springs, and then only because my aftermarket dual exhaust was in the way of some bolts, and had to be unbolted and hung down for easier access. Fortunately, none of the bolts were seized...the front eye bolt came out without any drama whatsoever.
If any of you remember my question about the coil spring compressor, I ended up getting one of the outside types, and it worked perfectly.
I jacked the front of the car up and put it on stands, removed the tire, then jacked the lower control arm up to completely compress the coil spring. I then attached the compressor and tightened it up a few more turns. Lowered the control arm and the spring came right out. So many of you said DO NOT get the outside type, but it worked just fine, and the coil did not flex or bow out at all.
The new springs didn't need to be compressed. I set the top in place, then spun the bottom part onto the perch. Took about ten seconds.
The rear sits at almost exactly the same height (I measured) as before, but now the front is an inch higher. Before the stance was slightly nose low, the way i like it, but now it's slightly nose high, like stock.
Next mods:
Lower the front another inch w/negative wedge kit. 4 wheel disk brakes. 17" rims.
Next mods:
)....that is why many people run 16x7 on the front because of the 'rumors'. I have alot of people that run 16x8 on the front with 4.5 bs and they didn't need the negative wedge to clear.
