the waterbox...
aar0s
1,015
55
69
When i went to the track for the first time one of my buddys that had been racing for a while told me to stay out of the water with street tires. The thought being that the fronts would get water in the treads and not get it cleared out before dragging it down the track. I have seen guys back into the box so as to not get the fronts wet to avoid this.
Lately ive noticed a lot of street cars pulling though the water with what im guessing are treaded front tires (most look to be street width, not skinnies). Was i misinformed or are there that many newbies that this is common with the "My new car is bad ass" crowd?:shrug:
i would think the same, (im not a big drag strip guy) but i think the water is more to help slicks and DR's to get broke loose for the burnout without chunking them but street tires dont need much to get going so no water is needed. also to big of a burnout on street tires will make them slip more than grip. if im wrong someone please correct me.
If you are running street tires stay out of the water box. Heating up a street tire doesn't aid in it's tracion and can actually make it worse and the other reason is the street tire will carry water with it up to the starting line in between the treads, even a small amount of water can hurt at the launch.
Thats kinda what i thought, although i have been known to burn off a pair of tires that i didn't particularly care for so i can move on to a new pair.:D
^ I've heard the same from friends with a LOT of drag racing experience. Stay out of the water with street tires, but give it a short spin just to knock the dust & sand off the tires. Then stage and go! :nice:
Don't be one of those tards who sits there and fries their street tires and leaves a giant cloud of smoke at the box...all you're doing is wasting tread. Drive around the water box, put it in second and just drop the clutch once and rip the tires real good....you don't even need to smoke them. I only do this to clean the tire off and make sure if i did get water or gravel or whatever on the tires that it gets rubbed clean before i launch.
do not drive any of your street tires through the box, you are asking for disaster. Also another pet peeve of mine - if the starter doesn't notice and direct you - stay out of the groove. Street tires rip up any of the good rubber laid on the track for cars running slicks and DRs. And if something breaks, or you start dropping fluid etc. pull off to the edge of the track and stop! Can't tell you how many hours I've sat in the staging lanes for oil downs because of guys staying the course
Drove around the water box, and of you have slicks on, back up to the water box until your rears are in it. Spin the tires a couple times, stop, pull forward 2-3 feet and THEN do the burnout. Don't burnout in the water box. Its just to wet the tires for a burnout ahead of the box.
Street tires, just pull around and do a quick spin to clear dirt and stuff from the tires.
My peeve is fwd cars pitting the front wheels in the water yanking the brake and proceeding to do a burnout in the box and drag water and dirt and crap forward :(
Ive seen several times where a guy will get to the end of the track and put something through the oil pan, fun times.
I once saw a guy with a monza who had a rag stuffed in the gas cap, he was escorted out and told not to bring his ass back!
I dont guess I know what your talking about by "the groove", this is a new one on me and ive never heard anyone complain about it.
Kids who do 5 min burnouts with their street tires Piss me off. Just drive around the box, spin them a little bit and go. There's really no heating up a street tire...idk what these guys are thinking. And yes BACK up to the water box especially if you're running a skinny with very little tread. You won't be too thrilled with your experience rolling down the track with wet front tires.
My track at least, they don't really have the street tire guys avoid the groove as it's not really a big deal IMO. Most of the street tire guys around here down lay down enough power to do much damage to the track.
The "groove" is visible from the starting line. It's basically the rubber that has been laid down from drag slick cars repeated trips down the track.It is the highest traction path to take if you need it. A street tired car does not. Most of the time, you only have to be 1' or so right or left to be either in or out of it. I agree that you should stay out of it. (If you had a high Horsepower car, you'd know real fast what the groove was as soon as you got out of it)
Ahhh, the local track is in its second season so the groove is still thin. I have seen a guy with slicks pulling up rubber off the track early in the season at a test and tune, i guess thats what your talking about.
+1. Spin street tires lightly just to knock the dirt off of them. Hazing them is a waste, the tread compound is completely different than any racing tire.
I'd usually try to avoid the water, but what I've found is the guys at the local track get lazy and the water ends up completely crossing the staging lanes, so there's no way to avoid it. I'm sure my fronts pick up a little water, but I've never had any problem with it. Of course my car is no high horsepower monster, so that could be part of it.
Ever seen an FNG in a FWD car drive around the waterbox, back his rear tires into it and proceed to do a burn out with his front tires? I tried to get this guy on camera, but he didn't do it a second time. Guess someone told him. haha...
We use to have this problem till they actually poured some boxes for the water, still have a little "overspray" that misses the box though.
