that is the smog pump stuff that pumps air into the cats.rocepp said:I ran a KOER test on my 96 mustang GT and it returned two codes. They said Thermactor air system inoperable on bank 1 and bank 2. Anybody know what the problem could be? I thought maybe the o2 sensers, but I just replaced them a few months ago.
apparently, if the cats don't get enough oxygen, they can clog up after driving for 30 minutes or so, causing a restriction that can kill performance. this may cause the behavior that seems like a miss to you. after the car sits for a while, the cats unclog and then it runs ok again.rocepp said:would this cause the car to miss?
BlackVert said:the guys here say that the thermactor pumps air to the cats all the time, not just the first 2 minutes ...
http://forums.stangnet.com/showthread.php?t=553202
As the thread link you posted stated the air is always pumping into the cats (the catalyst to break down the unburned HCs), it's whether or not it goes into the thermactor ports in back of the heads all of the time that the book said 20-120 second during startup.
mo_dingo said:The ports in the back of the heads are for the EGR, not the smog pump. Two different systems.
Scott
rocepp said:What if i don't have cat's on my car? I'm assuming i'm getting this code for that reason.
