Thermostat Help asap
what temps were you running before, and what temp stat was in there before?
a 180 is almost always a safe bet.
well i put the intake on, and now im running warmer than i used 2. I used to be just above the 2nd notch. Now im at the third notch so my gauge is parralellel _ . Is this normal? Ive never seen it run this warm before, and its really bothering me. I left the same thermostat that was in the old intake in this one.
Turn the car on with the radiator cap off and start pumping the top radiator hose for a few minutes while the car is running and then turn off the car and put the radiator cap back on and go for a drive and see how it goes...
yep, air in there will create some hot spots and erroneous gauge readings (please get a real gauge too).
good luck.
