thermostat question?
  • Thread starter Thread starter pistonhead351
  • Start date Start date May 19, 2006
pistonhead351
flim hunter
May 1, 2005
75
  • May 19, 2006
i have a 195* thermostat in my car right now and i just feel that it runs to hot. its usually at 200* and sometimes creeps up to 205*. should i just get a 180? what do your guys cars run at.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
May 19, 2006
  • May 19, 2006
205-210 is still very reasonable...180 is very common addition and run one in mine.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 19, 2006
  • May 19, 2006
I run a 180 and sometimes I think it's too cool but that's reading my stock gauges. I am going to be installing some autometer gauges in my car this year for sure.
Jaswir
578
Orlando, FL
May 19, 2006
  • May 19, 2006
i ran the same that you did... put a 180 in and noticed a big difference! i would do it!! kept it alot cooler! only goes to the second line... before it would stay in the middle! i need a aftermarket guage too!
HISSIN50
34
129
May 19, 2006
  • May 19, 2006
Agreed. My preference is Mr Gasket brand 180* though it really sounds like you are doing fine. Like Derek said, those temps are right on.
Good luck.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 19, 2006
  • May 19, 2006
where in Canada would I be able to get a Mr Gasket T-stat
HISSIN50
34
129
May 19, 2006
  • May 19, 2006
Roland, check your local speed shop. They're 10 bucks at mine. Otherwise, if Summit or Jegs ships to Canada for a reasonable rate, the stats are under 9 bucks IIRC (if you are placing an order for something else - so you dont get hit with big S/H for just a stat).
It could be worth calling local parts stores to see if they can order the stat for you too - one or two of the 'parts oriented' chains here can get them.
Good luck bud.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 19, 2006
  • May 19, 2006
I have a NAPA and a Car Quest 4 and 5 blocks from my house that would be handy if they can get them
maverick0716
3,924
Chilliwack, BC, Canada
May 19, 2006
  • May 19, 2006
I use a 180* Stant superstat. I drilled a little hole in it to aid in air bleeding when changing out the water.
8950HO
658
#10
  • May 19, 2006
  • #10
Canadian Tire sells high flow thermostats that work great.Good quality and bigger than the standard Mickey Mouse size.
They can also order performance parts.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
