Thermostat with a chip
  • Thread starter Thread starter Johnny GT
  • Start date Start date Aug 24, 2005
J
Johnny GT
28
Mn.
Aug 24, 2005
  • Aug 24, 2005
Was just wondering if anyone had any suggestions...
I have a 92 AOD GT 5.0 with a Hypertech Super Chip. There was a 160 degree thermostat in the car when I got it, but I heard that this is to cool. So I put in a 180, also took out the stock fan and put in a electric. Now when the weather gets a little warm I have a little trouble keeping the beast cool even on the highway. Tends top climb into the upper half of the stock gauge ? I have heard that you can go to a 160 with this chip? Should I change it back?
Was thinking about removing the air conditioner system also to get a little better flow.
ss93cobra
1,422
Wilmington NC
Aug 24, 2005
  • Aug 24, 2005
Something's not right here. With the 180 stat, the car shouldn't really get much hotter than that and if your fan has a temp sensor, it should engage to where you've got it set. Possibly a radiator or coolant issue. Either way, I'd stay away from the 160 stat as you'd mentioned.
HISSIN50
34
129
Aug 24, 2005
  • Aug 24, 2005
Yep. Once again, this is an example of why I post that one has to evaluate the car and cooling system rather than a stat rating. That same 160 in another car might run at 165 at all times. On your car, not so.
I would work on finding out why you run hotter - the lower stat rating slows down the inevitable (takes longer to get hot).
More info on the combo and when it runs hot, etc, would help people to help you diagnose the issues, if that is something you might want to do.
Good luck.
QDRHRSE
1,590
Palmdale, CA
Aug 24, 2005
  • Aug 24, 2005
It seems to me that the electric fan isn'r working as well as the stock fan. I don't think it has anything to do with the stat. What kind of electric fan is it?
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 24, 2005
  • Aug 24, 2005
Could be many many things. First off.. judging temp by stock gauge, that is just not the right approach. You need to get a decent gauge on there to establish if you actually are running hot. Once you've established that you are (if in fact you are) running too hot then continue to look at possibles. I would have to suggest the chip come out..not a fan of them, you can accomplish the same gains with a simple turn of the distributor..the chip may even be causing the issue. Hope to help a litte...keep looking things over and relaying the info to the folks on here..you problem wil get it's self solved.
J
Johnny GT
28
Mn.
Aug 24, 2005
  • Aug 24, 2005
The fan is a cheaper one , I suppose I could put a little more into it. Also I don't have it hooked up to a regulator at the moment. Even so, if I turn it on it doesn't seem to cool it down all that much, if at all!
If it is a nice cool morning, it (the car) will run great and rocks. But add a even a little humidity and warmth and she shoots right up there!
I'll have to give it the once over and do a little troubleshooting to see if I can come up with anything. I was mainly wondering about the thermostat and it sounds as though I should be running fine with the 180.
Thanks for the info!!!
HISSIN50
34
129
Aug 24, 2005
  • Aug 24, 2005
ALso, you said it runs hot on the highway. If the radiator is insufficient or unable to reject enough heat, the biggest fan in the world cant help - the fan needs more radiator in order to be effective.
I just mention that in case it helps you save some money.
Good luck.
J
Johnny GT
28
Mn.
Aug 28, 2005
  • Aug 28, 2005
is it possible that i had a little air block?
I got a chance to do a little troubleshooting today and I was thinking that my stat was sticking. So I followed the advice of jacking up the drivers side and checking to see if the stat opened up. It did seem to open up so I am wondering if I was some how air locked before?
I also pulled the computer and made sure that my Hypertech mod was seated ok. After all this I went for a little drive and the temp seemed to sit right below the half way point which I think is about right? Wasn't really able to get down on it as there was a lot of people out walking and even a lot of people out on my usual testing strip in the country.
But it does seem better...
The fan is pulling plenty of air so it shouldn't be the fan!
Have to see when I can drive it a little more.
HISSIN50
34
129
Aug 28, 2005
  • Aug 28, 2005
Sounds good. Cant offer advice on interpolating the stock gauge because everyones' is different. Very crudely, if it is below half and you notice no signs of detonation or other heat-related issues, you might be alright.
Good luck.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
