thermostat
legalize420
1,541
South Florida
if i am putting a new neck on with the new intake should i change the thermostat and if so to which one?also, im not sure if the neck/housing what ever its called i ordered has a gasket.i think it said it had the o-ring and it has a better seal then the gasket. is that true? thanks
I would put a better thermostat than stock in. I like the Mr Gasket 180* balanced HP thermostat part #4364. You can order this one at any Autozone, Advanced Auto Parts etc. It has greater flow areas than normal and opens within 2* of 180 unlike the stock one which may not open until almost 10* hotter than 190*.
There is a gasket for the thermostat housing, part #746 from Mr Gasket.
--Tim
--Tim
do i need a gasket if it comes with an o-ring. i think thats what they were saying but i wanted to see if you need the gasket also.
I would go evaluate it yourself once you see what you are working with, but I would use the gasket/o-ring that the intake manufacturer wants. If they would have you use an o-ring with a stock stat, then use the o-ring with a Mr G stat (which is an excellent choice).
Good luck.
