Thermostat?
  • Thread starter Thread starter Mysterio
  • Start date Start date Jul 24, 2005
M
Mysterio
101
Lakewood, Ohio
Jul 24, 2005
  • Jul 24, 2005
What * thermostat does a 1993 LX come stock with? I'm trying to find out if my thermostat and/or sending unit is bad. My car's thermostat is telling me that my car runs a steady 160-ish degrees or lower. THe other day I hit some BADD traffic and my **** rocketed up to 200-ish because I was very low on coolant. Now I'm trying to figure out if my thermostat is reading ~20 degrees lower than it should be and I was really running 220+ or if it's reading correctly and my car just runs real cool.
HISSIN50
34
129
Jul 24, 2005
  • Jul 24, 2005
Stock is a 195*F t-stat.
Does the upper radiator hose get hot and firm?
Good luck.
M
Mysterio
101
Lakewood, Ohio
Jul 24, 2005
  • Jul 24, 2005
Good luck.
I'll have to drive it around and let it heat up and check tommorow and see if it does.
SamSnyder
196
  • Jul 24, 2005
Dingdingding (bells going off). Your car should not be low on coolant. What caused that? It is true that 195 is too hot. On the other hand, 160 is too cold. In the words of Goldilocks, 180 is JUST RIGHT. But look for that coolant loss issue first.
Black 93 Fox
1,995
Vancouver,Washington
Jul 25, 2005
  • Jul 25, 2005
Like said befor find why your low on coolant. And 180 is right on the money for your t-stat.
1EVIL88VERT
314
Dyess AFB, TX
Jul 25, 2005
  • Jul 25, 2005
sounds like the t-stat is stuck open....do you feel pressure in the upper hose when motor is cold? and like the other guy said find out where coolant is going
M
Mysterio
101
Lakewood, Ohio
Jul 25, 2005
  • Jul 25, 2005
The upper radiator hose is stiff when the engine isn't running. Haven't even touched it when the motor was running cold/hot. I'm not 100% sure what my guage is reading, I BELIEVE it's reading about 150-170*.. Here's a picture for reference. This is what it heats up to and continues to run at steadily:
I was also already aware of a small coolant leak, just haven't honed down on from where yet. My main issue right now was trying to figure out if my thermostat is reading the right temperature so I can find out if i'm running cold/hot. Trying to diagnose exactly what's going on with that then i'll find the leak.
Black 93 Fox
1,995
Jul 25, 2005
  • Jul 25, 2005
If it doesnt really get any hotter then that I would think the t-stat is stuck open which it does when the t-stat goes south. Try replacing it with a 180 and see what happens.
M
Mysterio
101
Lakewood, Ohio
Jul 25, 2005
  • Jul 25, 2005
Ok, that is basically what I was wondering. I was thinking it was stuck open and that was most likely the problem. I'll have to buy a 180 and see what it does with that on there. Thanks for the input.
88 Fox GT
1,674
Iowa
Jul 25, 2005
#10
  • Jul 25, 2005
  • #10
Gotta be stickin open. I am running a stock 195° thermostat and even on a 100° day, mine runs right at or just a tad above the middle line on the gauge.
Black 93 Fox
1,995
Jul 25, 2005
#11
  • Jul 25, 2005
  • #11
Hey no problem let us know how the out come is.
M
Mysterio
101
Lakewood, Ohio
Jul 26, 2005
#12
  • Jul 26, 2005
  • #12
I bought a 180* Thermostat.. Installed it (I had a 160* in???? I guess the guy I bought it from must have put in a 160 since he lived in vegas? I dont know)... And the car was still running colder than it should so my Dad put his thermometer on the heater hose and it was reading ~175 so I went and bought a new sending unit and put it in and now as far as I can tell my guage is reading where it should be. It's reading slightly above the 3rd line up.. Dead Middle is 200* so Im figuring its reading at abut 180 where it should be. Thanks everyone for their input
HISSIN50
34
129
Jul 26, 2005
#13
  • Jul 26, 2005
  • #13
IMHO trying to make diagnoses from the stock gauge is not a good idea. You made a leap of interpolation faith that I would not. I know my stock gauge is off by 45*F at times.
Good luck.
M
Mysterio
101
Lakewood, Ohio
Jul 26, 2005
#14
  • Jul 26, 2005
  • #14
Good luck.
I knew the stock guage was off that was one of the problems. However it did have the wrong thermostat in there so I fixed both problems and now the guage seems to be reading pretty accurately. I'm just using it as a guess-timate to see if my car is running at the correct temp or running hotter than it should be. And now after changing the sending unit and thermostat it looks like the guage is reading pretty accurately.
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Engine Re-torquing intake manifold bolts question
  • 91GTstroked
  • Feb 22, 2025
Fox 5.0 Mustang Tech Mar 1, 2025
Jarhead67
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
