Michael Yount
Mustang Master
There should be no vacuum at all to the valve at idle. The computer looks at tps/rpm and if it determines the car's at idle, it should direct the egr switch to not put any vacuum at all to the valve. And at every start up it looks at throttle position and re-establishes idle condition/tps setting at idle - so it thinks you're idleing even at 900. Same is true at w.o.t. - no egr valve opening. But if it's a lot better with them swapped, why not drive it that way for a while and see what happens?
