think this is a good deal?
jeffs89gt
83
trick flow track heat upper and lower manifold, 70mm throttle body with egr spacer, 75mm mass air with 24lb injectors for $600. all of it is 2 months old at the most. its commin off my friends buddys car. how much hp do u think id gain from this to.... im thinkin 30s-40s? :shrug:
do u guys think its worth it
Absolutely worth it! On stock heads (assumption), you'd gain probably 20-30 HP from it, since they can't flow anywhere near that intake's potential, but the seat of the pants 'o meter will tell you there's more power. I'd hold off on the injectors until there's better heads though.
That's a damn good deal.
New:
Track Heat Intake - $450
70mm TB+EGR - $200-250
75MAF - $200+
24's - $230
That means your getting about 50% off. Injectors and MAF's rarley go bad or wear out unless they are damaged. The rest has little or no moving parts so once again, unless damaged, no problem.
I would recomend a better fuel pump, the stock 88lph combined with it's age is probally not going to be able to keep up.
hes sellin it cause his compuer took a **** and hes puttin a carbed 351 in. he has had the stuff on the car for about a month now.... and the last 2 weeks the car has not run due to the computer probles. i priced everything threw summit and it comes out to be about 1200 worth of stuff. all i need is gaskets... :)
