Thinking about swapping over to a Ford Racing Cam
SAY GO
148
My current setup
306
AFR 185's
Trick Flow Track heat
C4 with 3000 Stall
This is gonna be a nitrous car, but i want it to be a runner on motor to...
ive been thinking with the bigger AFR's and track heat of switching over to a Z or X cam
the specs are as follows
ZCAM
0.552" 0.552"
228° 228°
XCAM
0.542" 0.542"
224° 224°
does anyone know the LSA on these cams? what do you guys think? im looking for a good off the shelf cam, not a custom ground...thanks for yor opinion
Ide call comp if anything as everyone is gonna say the Ford Racing Cams are "Outdated" you have so much invested in your motor why go cheap on the cam? I know you dont wanna hear this but it would make your combo so much better. Anyways look at Comp or Trickflow stage II, somthing that is a newer grind, ide would want a split duration, to favor the juice maybe someone else will chime in, that is my .2
yes i hear ya, but all OTS cams started as a custom grind at one point or another :) i actually have a split duration cam in there now 221/232 .570 lift with the 1.7 rockers. with a 111 LSA i heard a high LSA is favored for nitrous cars...what do you think?
