Thinking about switching back to NA, need help with a recipe.
96pushrod
Advanced Member
May 15, 2018
776
466
73
28
Savannah
Can't argue with a dyno graph. That's about the same ratios as my Systemax 2. Which heads are you running?
Kurt
Some 205 11rs. The lower has a port match, but really nothing special with the combo. The cam is what some would consider smallish: 226/234 @.050 .576/.571. It is nice for driving though, especially in traffic.
  • Sponsors(?)
revhead347
I have face herpes.
8,015
980
214
40
Acworth, GA
My cam is very close to that. Custom grind with 112 lobe seperation. It also drives very nicely. I had a much larger cam in it before, but it really killed low end power, and drove terribly. To this day, my foot has a twitch when I drive. You kind of had to work it in and out like running an old sewing machine to get it to drive without bucking or surging. I am still on my old Canfield 192cc heads. That was what I was referring to with the "new stuff." I would love to have a set of 11Rs, I am sure they would put me in that ball park. I am still at 10.0/1 static compression ratio. Back in the day, that was as much as most engine builders were willing to throw at a pump gas engine.
On a side note, I got my shifter bezel in this morning. I obviously wasn't able to remelt the factory plastic tabs, but I attached the boot to the bezel with a thick layer of Ultra Black RTV, and it seemed to work out just fine.
Kurt
96pushrod
Advanced Member
May 15, 2018
776
466
73
28
Savannah
Kurt
Nothing wrong with some Canfields. However, It is tough to beat some of the newer options when it comes to sbf heads nowadays. It’s crazy to think that you can get a badass set of cnc ported heads delivered to your door in a matter of days for less than $2000 - all with the latest and greatest valvetrain. That’s one thing I love about the 11r package, the spring and valve package is top notch. Essentially it’s ls stuff.
As far as compression, that’s essentially just free (kinda) horsepower. If you crunch numbers on my dynamic cr you would find that it’s scary high. It works for me though, no issues with detonation.
That’s great! I’ve got a bezel that just has the boot rtv’d as well. If rtv is good enough for planes, it’s good enough for me
revhead347
I have face herpes.
8,015
980
214
40
Acworth, GA
How high is your static compression? Valuable information for the OP. I think the best way to go is just to get a flat top piston and 0 deck the block. I actually have a dish piston to bring the compression down. Whatever the compression comes out to be with a flat top, grind the cam accordingly. I don't think running dome pistons on a street engine is a good idea. I agree on the 11R heads; it's a killer head package with the best stuff. My Canfields were $1600 hand ported back in 1999. That was the price I was able to get because I knew people. CNC heads had just come out, but only on the small TF 170cc, and Performer RPM heads. If you wanted a big head (which the Canfield was the biggest street head you could buy at the time), you had to get the work done. Every head needed a valve job out of the box. No idea why the factory valve jobs were so bad back then.
I don't care if the boot is just RTV'd on, as long as it clips down tight. Not worried about things I can't see.
Kurt
96pushrod
Advanced Member
May 15, 2018
776
466
73
28
Savannah
Kurt
Static is 10.8. Flat top and 0 deck is the way to go. You can run like 29* if timing with the 11r with flat tops for best power.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,031
5,950
204
31
Hillsborough county
The 11R head does not like alot of timing that is for sure, the chamber design is superb. we lost MPH advancing above 29* in the 1/4mile.
96pushrod
Advanced Member
May 15, 2018
776
466
73
28
Savannah
Yes, a very efficient chamber for sure. Really my only complaint about the heads is the don’t have the spread bolt hole pattern for headers. Besides that they’re great.
John Dirks Jr
5 Year Member
Jun 28, 2013
2,763
1,154
174
56
Maryland
Get a 351 block and stroke it out to 408. That is a good place to start your NA setup. Then you can stay milder on the cam profiles and still make the power and TQ that you want. Actually, bigger cams will seem milder in a bigger cube engine too. An engine with gobs of mid range TQ and a less high strung attitude will last longer and be way more streetable.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,031
5,950
204
31
Hillsborough county
Thats what i am doing with my 393w, going to be running my blower cam in it for now. Heads flow 260cfm with a 224/236 575lift 114lsa... should drive and idle like stock and still make great power. I plan on dyno numbers NA before i get stupid
John Dirks Jr
5 Year Member
Jun 28, 2013
2,763
1,154
174
56
Maryland
I think I got my 302 to just about the safe limit with 400 at the wheel with 10psi. I'd love to do a similar setup on a 351 block. I'm sure it would be 500+ and totally streetable and mild mannered.
revhead347
I have face herpes.
8,015
980
214
40
Acworth, GA
You guys are misunderstanding airflow. The engine makes as much power as the heads will flow. If your 302 heads and blower make 400hp at the wheel, putting a 351 short block under all that will make 400hp to wheel at 500rpms lower, and that's it. Increasing the stroke will not substantially increase peak power, if at all. If anything, the added weight of the engine will only make the car slower. The stock 302 block is more limited by rpm than torque.
Kurt
John Dirks Jr
5 Year Member
Jun 28, 2013
2,763
1,154
174
56
Maryland
I thought I understood that more cubic inches would be capable of ingesting more air. As long as you can match the increased air ingestion with the correct amount of fuel, that makes more power right?
John Dirks Jr
5 Year Member
Jun 28, 2013
2,763
1,154
174
56
Maryland
Anyway, the longer stroke engines will make more tq at a lower rpm than the shorter stroke engines. And tq is what gets the mass moving down the track. Increase tq enough and you can use a higher ratio rear gear and still run the same time. And the higher ratio is much nicer for highway cruising.
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
I swapped out my 4:10 to a 3:73 in my stock block H/C/I 5 speed and it lowered the rpm at 80 mph some 500 rpms. Yuge improvement.
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
13,586
234
62
Birmingham, al
m.imdb.com
A 114 lc n/a cam will be a pig. W/o a more traditional n/a grind to compare it to, you'll probably think that you're making decent power, but I'd bet comparitively that you're not.
If you're building a street motor for an N/A application, everything that revolves around that engine getting air in and out as efficiently as possible, All while being able to take full advantage of each power cycle w/o dumping part of it out the exhaust port. Anybody that thinks a cam optimized for forced induction is gonna work in a N/A application is kidding themselves.
It's gonna work, but not as good as one built for that purpose. Otherwise, we wouldn't need the Freezy's of the world...one cam should do it all.
Reactions: revhead347
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,031
5,950
204
31
Hillsborough county
The get stupid part is the turbo I have planned Mike. .. if I put together a combo with a NA cam then it wont be worth a :poo: with boost...
EX-SSP
80
42
28
30
New York
Kurt
I can vouch for this. I put together a 347 earlier this year and got the wrong heads and cam. I currently make 360hp/395tq at the wheels. Why? Because I got TW 170 heads and an Anderson N41 cam. Would be great for a 306 motor but not my 347. Needless to say, I am currently shopping for an upgrade. Live and learn.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,031
5,950
204
31
Hillsborough county
IMO the best heads for a combination are the ones that provide the most port velocity where you need it. Will larger heads provide a higher peak value, probably.. will they have more power under the curve in the RPM range where you want/need it.. maybe.
I dont care much for peak numbers, they look great on an internet post and thats about it.
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,971
3,507
194
44
Spokane, Wa
Any plans I had are shelved now. The publicly traded company I work for announced that they are closing the location I work at and relocating to Boise, Idaho. They offered me retention and a promotion but I declined. Come March 31st I'll get my severance and be looking for a J O B.
What can I do in the mean time? Well I still have NIB parts to install like my HID retrofit kit from TRS, my ProMeth kit, and new Ford door seals to replace the 50Resto junk seals that won't let my doors close all the way.
I wish you guys the best through the holidays :coff:
Thread starter Similar threads Forum Replies Date
StreetDreamsGT Need Fuel Pump Relay Pin Info, I think I switched the pins around Fox 5.0 Mustang Tech 1
1 Need Guidance Thinking of switching cat backs Fox 5.0 Mustang Tech 1
riz91302 Thinking about switching to carb setup<<NEED ADVICE!! Fox 5.0 Mustang Tech 7
Old Skooler Thinking of switching to EFI Fox 5.0 Mustang Tech 0
0 12lbs Intercooled Vortech with 3.90 rear... thinking about switching to 3.55 thoughts? SN95 4.6L Mustang Tech 11
Venom351R Thinking of Switching Intakes but is it worth it? 1994 - 1995 Specific Tech 33
N8Miller Thinking of switching to SVO sail panels... any opinions? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
astronut1885 I think I'm switching over to the 4.6 crowd... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 54
C Total noob thinking of switching to mustangs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
Jsun3701 Thinking bout the switch Petro to Syn oil SN95 4.6L Mustang Tech 12
O thinking of switching to mgw short shifter... SN95 4.6L Mustang Tech 12
MGSTANG Problem after installing window switch (don't think related) SN95 4.6L Mustang Tech 2
0 Thinking of switching from Magnaflow to Magnapacks, will I lose Power? SVT Tech Forum 3
1105 Thinking about switching intakes. 1994 - 1995 Specific Tech 6
BlackVert Thinking about switching to a 94/95 5.0 ... Fox 5.0 Mustang Tech 5
BlackVert Thinking about switching to a 94/95 GT ... SN95 4.6L Mustang Tech 8
BlackVert Thinking about switching from my 1996 GT ... 1994 - 1995 Specific Tech 16
P Thinking about switching rear gears 1994 - 1995 Specific Tech 7
M Thinking of switching my 4.10's for some 4.30's, how much quicker et's SN95 4.6L Mustang Tech 8
awing I think I broke my PS pump Fox 5.0 Mustang Tech 9
Boosted92LX Just when I think I’m out 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 39
H A/c PROBLEM think it maybe a compressor Fox 5.0 Mustang Tech 32
A Engine What do you think? Fox 5.0 Mustang Tech 29
usaf_branham Thinking about buying my old car back 1996 - 2004 SN95 Mustang -General/Talk- 11
T Thinking about headers,04 gt SN95 4.6L Mustang Tech 2
79 Fox Something else too. I think I know what is the problem, but I'd like clarification. Fox 5.0 Mustang Tech 7
D 1998 GT Electrical Problem... I think? 1996 - 2004 SN95 Mustang -General/Talk- 5
Real time recon Before you even think about talking down to a Fox 5.0 302 Engine... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
S What do yall think? What is it Worth?!?!? 2
2000xp8 93 cobra with 20's, it's not as bad as one would think... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
2000xp8 Not sure what to think on this one 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
M I think I blew a hole in my timing cover 351w, help needed 1965 - 1973 Classic Mustangs -General/Talk- 2
K Electrical Can't find issue with starter. Tried everything I can think of. SN95 4.6L Mustang Tech 2
billison Thinking of ditching my e fans 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 95
C Thinking of selling 2001 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 1
cobra commander72 What do you think 2005 - 2014 S-197 Mustang -General/Talk- 12
K This is my Stang, whatca ya think? 2005 - 2014 S-197 Mustang -General/Talk- 1
W Hi All, Just got a 2002 mustang. It has 16 inch wheels and tires on it. Thinking about buying 18x9 front and 18x10 rear, any advice? 1996 - 2004 SN95 Mustang -General/Talk- 2
B 2001 rear end whining I think SN95 4.6L Mustang Tech 0
FoxMustangLvr Thinking about going TURBO, talk me out of it? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
K Thinking of buying a 1990 mustang LX as a parts car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
M 2007 GT - Stereo continually thinks I’m loading a CD 2005 - 2014 S-197 Mustang -General/Talk- 1
9 Anyone try Motor Medic - Motor Flush ? I think it works GREAT! [proof] Other Auto Tech 1
J I think I have Piston Slap in my 2015 Mustang GT 2015+ (S550) Mustang -General/Talk 4
GroverDill Found these canvas prints of some old Fox, think anyone would want these? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
D New to Mustang, thinking of Shelby GT The Welcome Wagon 5
C What do you think??? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
billison Thinking Of Ditching The Cobra Stuff. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
Ratmann1 Progress Thread I Think Im Being Hosed On My Window Repair Need Advice 1996 - 2004 SN95 Mustang -General/Talk- 3
T Anyone Know About Knock Sensor. I Think This Is What It Is. How Is It Hooked Up 1996 - 2004 SN95 Mustang -General/Talk- 0
