I ran the 3" crank pulley all the time with not problems. Along with the other U/D's the alt didn't even start to charge until about 1700rpm, and that's a 3G 160A unit.
When you run a bigger water pump pulley you are slowing it down twice. Once from the crank pulley and once again with a bigger water pump pulley. The difference between the two water pump pulleys is minimal. All the other pulleys are still spinning slower. Difference between my setup and a full set of underdrives 2 to 3 hp.......and never having charging or cooling problems.93tealstang said:Without running a bigger water pump pulley, I'd think there wouldn't be much gain with your setup since your not really reducing anything to make power. It does seem logical since your not loosing colling or charging abilities but how much of gain do you think it might be worth over a full set of underdrives?
Michael Yount said:Uh - with a reverse rotation pump, the BACK of the serpentine drives the water pump, not the ribbed part. I've not seen one with a lip to keep the belt on. Mine's factory -- no lip.
If you want to buy from ASP buy the 4 inch crank pulley for $49.95 part# ASP520100 and buy the overdrive alternator pulley for $19.95 part# ASP520004BlueOvalStangGT said:Ive been there but there is like 3 different sets for a fox.
