Thinking of installing my tranny
mity2 said:
Do you know how to get to those bolts which is located INSIDE of bellhousing?
Because i don't:shrug:
o0o0o i did not know this, i was thinking of the T5 where you can seperate the two. my bad
oh and about the DS bolts, you probably have to take a torch tothem and heat em up first
My bolts were also on tight. This might sound strange, however, I had to use my leg on a cheater bar instead of my arm to finally get the bolt loose. Just be careful not to strip it :nice:
well i got the driveshaft bolts out finally had to put it in gear and use a 3/8 ratchet with small extention and a breaker bar...worked like a dream all the other bolts are loose and I will drop it out in the morning.
The top starter bolt on mine was only hand tight and not all the way in so i just unscrewed it(lucky me):nice: someone must have had to take it out before.
I am doing all the work by myself because I cant find anyone to help me due to conflicting schedules. But I should have the new one in tomorrow before I go to work.
Not too bad of a job to do but it really blows doing it on jackstands in a rock driveway:nonono:
