  • SVT Tech Forum
third gear grinding
  • Thread starter Thread starter 01svt-cobra
  • Start date Start date Feb 26, 2006
01svt-cobra
  • Feb 26, 2006
I recently took my 01 cobra to the track and I ran it several times and all day it was really difficult to hit third gear. So I messed with the stops in my shifter and ran two more times the second time I hit third and it grinded really bad. So I took it on the road just crusing and even when I shift into third slow it grinds every time but it still goes into gear. What is wrong and will my warranty cover this.
D
ddv98cobra
Canton, OH
Feb 26, 2006
  • Feb 26, 2006
I had the same problem in my 98 cobra, I couldn't get it into third gear very well and it would grind. Eventually it wouldn't even go in. Turns out there was a crack that had propagaited through the top of the shifter fork where it hooks into the rail. I replaced the whole transmission with a racing one, it was about 2 grand. I'm not positive that the 01s have the same tranny, but the situation sounds very similar. The shifter fork was just a lightweight piece of aluminum and isnt really heavy duty enough for racing. Oddly enough, about 2 months after I replaced mine, a friend of mine with a 98 had the exact same problem.
69 Rustang
307
Orange County California
Feb 26, 2006
  • Feb 26, 2006
I blew a shift once (the floor mat held my accelerator pedal down) and fried the 3rd gear synchro--sounds like the same symptoms I had--it ground trying to go into gear, once in, it was OK. It got worse quickly and I could not get into 3rd at all due to fear of causing more damage.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
M
Drivetrain 5 speed will not shift at all
  • Meadecomustang
  • Mar 4, 2025
Fox 5.0 Mustang Tech Jul 29, 2025
AeroCoupe
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
  • SVT Tech Forum
