I was running no pipes or mufflers for a while (nasty driveshaft problem took the both out ), which I would guess is as close to no back pressure as you can get. I went and put on exhuast and picked up et and 2 mph. I don't think and motor NEEDS back pressure, but because it doesn't need it to run right, that doesn't mean that adding some will not benefit the car.
I think the whole idea of backpressure thru exhaust is misunderstood. It's not the actually restriction on the way out of the exhaust that causes the low end torque. It's the scavenging of the cylinder gases caused by the vacuum behind the exhaust pulse infront of it. A gas pulse exits the header and enters the pipe. On the way out it creates a suction behind it. When the next valve opens, the gas is actually pulled out of the cylinder, rather than being pushed out ALL by the piston. If your exhaust is too big for the amount of gas exiting, it will not form a "seal" if you will. And if it doesn't, you now have no vacuum behind the pulse and no scavenging effect.
