this is how...right?
  • Thread starter Thread starter carbed87
  • Start date Start date Aug 27, 2005
carbed87
215
  • Aug 27, 2005
alright, this is AS FAR AS I KNOW how you adjust valves. fill me in on anything i'm missing and/or doing wrong.
1. with valve covers off, and both intake plenumns off, i start with the number 1 cylinder.
2. starting by turning the crank until the intake valve JUST starts to open, i adjust the exhaust side, by tightening down the rocker, until i see the "plunger" on the lifter depress just a sack hair (about 20 thousands of an inch).
3. rotate crank until the EXHAUST valve just begins to open, and do the exact same thing.
4. and do so to the rest of the cylinders.
5. go through all rockers and tourque them to about 18lbs.
the part i dont get, is shimming them,
why do i need to, what does that mean about my pushrod legnth?
if i need to shim my rockers with more than two shims, does that mean my pushrod is too long or short?
the heads i have are: cast iron gt-40's with pedistul mount rockers.
PLEASE: fill me in on anything that i'm not doing right, ANY help is GREATLY appriciated. thanks
im getting by these heads
9
91LXzzzH-T
  • Aug 27, 2005
my friend just read this thread and he said you need to set your valve spring pressure to 1400 psi before you even start
z9_87
332
Urbana, IL
Aug 27, 2005
  • Aug 27, 2005
um excuse me but, wtf 1400 psi. wow, the 9alx guy has it going 1400psi valve springs and he wants to put an acura motor in a fox!
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
