this is really trippy
  • Thread starter Thread starter flyboy86
  • Start date Start date Oct 18, 2007
1 of 2 Next Last
F
flyboy86
94
Vance AFB, Enid OK
Oct 18, 2007
  • Oct 18, 2007
http://www.switched.com/2007/10/15/the-trippiest-optical-illusions-on-the-net/
I got to the point where i can see it both ways, and i can switch it. Really trippy though.
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 18, 2007
  • Oct 18, 2007
counter-clockwise but i'm usually a logical guy. Often to my own fault. But after awhile, i notice it moving the other way, clock-wise. My Psychology Journal tells me that this means my brain trys what it's used to using to solve a problem, then eventually turns to the other method, in this case, using creative observations. "An action most regularly observed among mature (age) people's brains, commonly perceived as wisdom"
propellerhead
1,541
"but what's with the but shots?"
Oct 18, 2007
  • Oct 18, 2007
Initially, clockwise. Then after reading a little and glancing back at the pic, counter-clockwise. Then it would switch.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Oct 18, 2007
  • Oct 18, 2007
i call i watched it a few times, and i can see it change directions right in the middle. i get a small flicker, then it changes.
F
flyboy86
94
Vance AFB, Enid OK
Oct 18, 2007
  • Oct 18, 2007
I saw the flicker too, and i initially though bs, but then i got good at changing it on my own command. Looking out the corner of my eye at it is the easiest way for me to change it.
D
Daggar
3,902
  • Oct 18, 2007
I don't get it. For me at least, she turns clockwise and stays that way. I don't understand the optical illusion portion of it because her right foot always travels from the right side of the screen to the left side of the screen and infront of the rest of the image.
So I for one, cannot see how it could be percieved as spinning in the opposite direction.
D
Daggar
3,902
  • Oct 18, 2007
After watching a bit longer, I saw it swap directions too. It appears to swap randomly.
F
flyboy86
94
Vance AFB, Enid OK
Oct 18, 2007
  • Oct 18, 2007
It depends on how you see the raised leg, whether it is in front of her body, or behind. I thought the same way as you, until I looked at something else, off the screen, and looked at it in the corner of my eye, then it sudddenly flipped. Now i can make her change directions before she even finishes a full revolution. Another tip...stop looking at her perky little nipples
D
Daggar
3,902
  • Oct 18, 2007
You're right. I've got it down now. I can change the direction at will now.
Try looking at and concentrating on the shadow of her straight foot. Once you get the foot to rotate in the direction that you desire, you can then look at the whole image turning in that direction. Pretty kewl.
D
Daggar
3,902
#10
  • Oct 18, 2007
  • #10
That is def a trip. I wonder if they set out to create that illusion or if they just stumbled onto it?
F
flyboy86
94
Vance AFB, Enid OK
Oct 18, 2007
#11
  • Oct 18, 2007
  • #11
idk, i'm just glad that they added a nice rack and nipples
D
Daggar
3,902
#12
  • Oct 18, 2007
  • #12
Yeah... the nips are a nice touch. lol
Shiroelex
There's nothing worse than aut
728
Westland, MI
Oct 18, 2007
#13
  • Oct 18, 2007
  • #13
I've been switching my tv between Law and Order Criminal Intent, and Overhaulin'. She spins clockwise when I am watching Overhaulin, and counter-clockwise on Law and Order. Weird.
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 18, 2007
#14
  • Oct 18, 2007
  • #14
it's dependent on what frame your mind initiates the string w/. If it starts w/ the foot's reflection on the floor pointing left it will make your mind will assume counter-clock wise. If it initiates with the reflection pointing to the right then vise versa. You have to use the reflection because that's the only 2d object that you don't have to rely on depth perception with, due to one not being sure if the leg is going behind or in front of the girl. Clockwise is more common, for right handed dominate people assume all "swirl" movements are this way before the brain shows it to be wrong.
D
Daggar
3,902
#15
  • Oct 18, 2007
  • #15
I'm not sure that it's dependant on the frame that you pick up. Everytime I look, she's moving clockwise. I have to concentrate to get her to move the opposite direction.
DTNODYA
831
#16
  • Oct 18, 2007
  • #16
This is one of the coolest illusions ... stare at it like you are looking at one of those 3d picture deals. Then look away and look back at it. Once you get it down, you can control it with your brain and make her go either way. It's crazy the first time you see it!
2000fordstanggt
404
Westland, MI
Oct 18, 2007
#17
  • Oct 18, 2007
  • #17
www.seizurerobots.com
thought this would be appropriate
D
daleclough
18
#18
  • Oct 18, 2007
  • #18
All clockwise....
scupking
1,186
Enfield, CT
Oct 18, 2007
#19
  • Oct 18, 2007
  • #19
So more things for you guys to try out. http://www.subversiveelement.com/Optical1.html
Wolvrin704
120
Milford, OH
Oct 19, 2007
#20
  • Oct 19, 2007
  • #20
If I just look at her without concentrating it always counter-clockwise. If I stare at the calves for about 30 seconds it switches and stays that way until I look away, then when I look again its counter-clockwise again.
1 of 2 Next Last
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Fox 5.0 Mustang Tech Today at 10:20 AM
Dakar09
D
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
