This problem I'm having is getting really anoying.
Red Lx
Hey guys....
I'm new to the forum. I've had two Stangs since high school. A beautiful white 92 LX 4 banger....i know i know....and my current one..an 88 Black 5.0. I'm having a big problem with my 88. Every now and then I get a miss fire (or back fire, it's coming up through the intake.) It comes and goes...but latley it's getting bad. I checked the fuel press...it's definitly low. I replaced the press regulator because it wasnt holdin any fuel press with the ignition off. That didnt help the low fuel press problem. I checked for leaks and have none. I also checked for vacuum leaks and have none. Could it be a bad fuel pump or relay? I know it's definitly starvin for fuel. Any help would be appreciated. Also it really dosent want to move out of its own way when this happens. It just bogs down so bad. It's an all original car (hopefully not after this summer) With just a flowmaster after cat (of course). Thanks again.
Any codes? Lack of fuel pressure often leads to an O2 rich adaptive limit code. While retrieving codes, run a cylinder balance test to see if the computer can pick up which cylinder is missing.
A fuel pump failing is more likely than a FPR. Can you watch fuel pressure while you drive? In my experience, when a fuel pump is crapping out because of a weak diaphram, as the pump gets hotter (more run time in a given driving session), the pressure drops. Once the car starts to miss, it's a couple minutes or less before it stalls and won't restart.
Good luck.
