Those of you who bought the kit, how was the fitment for you? I put the caliper over the rotor without pads, and it seemed to fit fine, as far as the bracket adjusting the caliper to the right spot. But with pads, it screws everything up.
Maybe the piston is out a little and causing the inner pad to not seat all the way in. If this is the case, how can I get the piston to move back in?
Any other thoughts about what I could be doing wrong?
Also, do I have to use the anti-rattle clips or can I install the new pads without them?
fyi: using Hawk pads
Thanks
Dave
Thanks
Dave
