- Dec 15, 2006
- 25
- 0
- 0
O.K. Guys. I could use some help shortly to keep me from wasting time and doing something I don't need to be doing. Here's the deal. I'll admit up front that this was my first manual transmission that I've messed with. Past experience was with automatics... I thought I had everything covered though.
I just swapped a 5.0 / t-5 out of a damaged '88 GT which only had 66k miles on it, into a '87 GT roller which was a 5.0 / t-5. While I had the engine and tranny out, I installed a brand new King Cobra Clutch, Pilot Bearing and Throwout Bearing exactly as all the manuals I could get my hands on said to do. I did this to obviously prevent any possible issues when I re-installed the engine/tranny combo!!!
I had ordered a new Clutch Cable, Adjustable Firewall Adaptor and a 3 Fork Clutch Quadrant with the King Cobra Clutch, just to make sure I had everything I needed. Upon installing the engine/tranny into the '87 GT I seen that the previous owner had already installed a large grey sheathed Clutch Cable with adjustment at the Clutch Fork only and a blue Steeda Single Fork Clutch Quadrant, so I didn't bother installing my new parts at this time.
The problem is, when I start the engine, there is a constant knock coming from the flywheel, clutch, bellhousing area. Also, the clutch pedal is so hard to push down that I don't think my wife or your average driver would be able to operate this car. The transmission will go into gear, shift and drive. I just read somewhere in one of these posts that different clutch cables may need to be used with different clutches. Could this be the problem? I hope so, seeing I don't really want to pull the transmission back out of the car at this point, but whatever I need to do needs to be done. Also, would the 3 fork Quadrant make the Clutch Pedal a little softer??
Sorry for the long story! Just wanted to try and be as clear as possible... I'd appreciate any help you guys can give!!!!!!!!!
