  • 1994 - 1995 Specific Tech
threadchaser // tap n dye
  • Thread starter Thread starter 95GTV8
  • Start date Start date Nov 5, 2005
95GTV8
386
Washington State
Nov 5, 2005
  • Nov 5, 2005
anybody have any experience with these? I ordered my new MM strut tower brace and when i went to put it on i noticed 1 of my screw holes on the firewall was stripped out, and on the driver side strut tower the on that goes in on the side is also stripped out. So should a threadchaser /tap n dye and some wd-40 do the trick?
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 5, 2005
  • Nov 5, 2005
the thread size for those holes is m8x1.25, so just run a tap through to clean up those holes.
95GTV8
386
Washington State
Nov 5, 2005
  • Nov 5, 2005
allright thanks, my booklet said 8 mm, but it's 8mm x 1.25 mm? that will help alot when i go uptown and grab those chasers. I've never used them before but my neighbor came out and said i should try that.
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 5, 2005
  • Nov 5, 2005
its definately that size, it just goes in like a regular bolt.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Nov 6, 2005
  • Nov 6, 2005
I know it's too late now, but you can order a semi-decent Tap set for about $20 on Harborfreight.com.
RC
Zero Signal
2,633
Tucson, AZ
Nov 6, 2005
  • Nov 6, 2005
Good one RC, that's a nice deal with the lifetime warranty.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 6, 2005
  • Nov 6, 2005
Yup, a tap/dye set from harbor frieght is great for rethreading existing threads. I wouldn't use it for creating brand new threads though. I had a broken tap inside my engine block to prove how easy it is to snap one off.
I bought the rethreading kit from sears, runs $50 and it has many of the common NC and NF threads in our cars. Plus the coarse/fine metric threads as well. They also have dyes in the kit in all those sizes to fix bolts. They work great, saved my butt a few times.
Scott
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 6, 2005
  • Nov 6, 2005
harbor freight is good for the cheap, use it a couple of times and it breaks or bends, tools.
94GTLaserRC
11,178
Nov 6, 2005
  • Nov 6, 2005
For what I do at home...That's good enough.
HF ROCKS for air tool accessories!!!
RC
Zero Signal
2,633
Tucson, AZ
Nov 6, 2005
#10
  • Nov 6, 2005
  • #10
Yeah I wouldn't bet the farm on those things holding up, but if I needed to really make new threads I would probably buy nice ones individually as I needed them.
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
T
Missing brace
  • Texas275
  • Feb 6, 2025
1974 - 1978 Mustang II Talk & Tech Feb 7, 2025
extra_stout
