threadchaser // tap n dye
95GTV8
386
Washington State
anybody have any experience with these? I ordered my new MM strut tower brace and when i went to put it on i noticed 1 of my screw holes on the firewall was stripped out, and on the driver side strut tower the on that goes in on the side is also stripped out. So should a threadchaser /tap n dye and some wd-40 do the trick?
allright thanks, my booklet said 8 mm, but it's 8mm x 1.25 mm? that will help alot when i go uptown and grab those chasers. I've never used them before but my neighbor came out and said i should try that.
Yup, a tap/dye set from harbor frieght is great for rethreading existing threads. I wouldn't use it for creating brand new threads though. I had a broken tap inside my engine block to prove how easy it is to snap one off.
I bought the rethreading kit from sears, runs $50 and it has many of the common NC and NF threads in our cars. Plus the coarse/fine metric threads as well. They also have dyes in the kit in all those sizes to fix bolts. They work great, saved my butt a few times.
Scott
