Throttle Body Coolant ?Bypass?
1991RWHP
59
Illinois
I got myself a 70MM BBK TB/Spacer ... after thinking about the " coolant passage " for the heated throttle body, wouldn't it make sense to bypass those so then i can have a true, or somewhat true COLD Air Intake?
I guess im asking if it would make sense to bypass the heater hoses for the throttle body. Is it a common thing to do, any problems with doing it?
Let me know, thanks!!
:stupid:
i always supported the notion that its a BAD idea to bypass the EGR coolant.
while coolant is hot, the exhaust gas is even hotter, thats why the coolant is there.
if your EGR is working, leave it there.
only time i would plug it off is only if you have your EGR totally blocked off from getting to the EGR spacer. even if you have an EGR spacer delete. there is still hot exhaust making its way up there. you need to block it off at the cylinder head.
most intake gasket kit come with a small insert to block it off.
on my car, i just welded the hole up since i had access to a welder.
