throttle body coolant?
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
yesterday while replacing the throttle body gasket i noticed there was a coolant line going to it and that coolant had been leaking in between the gasket on the throttle body and the intake plenum. My question is, can someone please explain to me why there is a coolant line running to the throttle body?
Those lines in and out of the TB are used to affect EGR temps..If you had coolant leaking then def get the gasket replaced and tighten her up. I would change the oil also..I don't like the idea of coolant getting into the engine..especially anywhere near the oil.
It has been done on many motors. The EGR gasses can be 600-700*F++ so the 200*F coolant helps cool the housing that your cool incoming air is passing through.
Derek's advice is quite good. :nice:
Good luck.
The only time to by-pass coolant to the EGR spacer is when the EGR system is eliminated,eg,blocking off the EGR ports in the cylinder heads.
Otherwise the coolant is there to cool the EGR spacer that carries the hot exhaust gasses from the cylinder heads through the intake manifold.
If the EGR is functional,don`t disconnect the coolant lines :nono: .
I've heard that as well to not disconnect them.. my buddy has a '95 Bronco with a 5.0, he capped off both the lines, hasn't had an issue.. guess it's a preference thing. Mine are intact.. barely.
I am a little confused, but I guess that is normal.
If the EGR gasses run to the intake air via the lower and then upper manifold, then why did Ford not cool the entire intake? It seems pretty meaningless to cool the TB when the exhaust gasses have already dumped all that heat into the lower and upper intake.
Also, I have heard some debate on this. Some feel the coolant lines were there to bring heat to the TB for quicker warmups. Did the stock coolant line routing bring hot coolant that had just left the block to the TB? I haven't seen stock in a few years so I don't remember.
I just wanted to toss this out to see what all of you really smart guys think.
Also, I ran my Cobra manifold on the 302 for a couple of years w/o the coolant running to the EGR. Didn't seem to have any heating/cooling problems.
jason
Ford installed the coolant lines to keep the throttle body from possibly freezing in low temps, but like vristang said, the Cobra intake eliminated it.
So to answer your question, you can keep it or cap it, it won't effect on how your car runs.
If one wanted to de-ice the TB, the lines are not going to the correct component. Furthermore, a heat riser off the headers would be more effective in this capacity.
I have to respectfully disagree with the freezing TB theory as well.
I don't see how any part of the engine could freeze when it was running, regardless of ambient temps. When the motor is not running though the coolant lines wouldn't do any good anyway. :shrug:
Without knowing what Ford was intending with these coolant lines, I hesitate to give a recommendation as to whether or not they can/should be plugged.
Exactly, because they aren't going to be hot until the engine is hot. And when the engine is hot, it's doing fine heating the TB.
I don't know what they're for. I don't buy the cooling theory due to the Cobra intake, and I don't buy the heating theory due to the coolant warm up issues.
I think maybe they were an idea for something else and just got left behind somehow. :shrug:
