I removed the coolant going to the throttle body and rerouted it under the body.Is the coolant designed for emissions through the throttle body?Also wanted to set my timming to 16 degrees to help with pick up. Are these good ideas and are there any more you can think of? 1990 5.0 LX Hatchback.K&N FIPK,O/R H pipe ,2.5 CATBACK Flowmaster series 40.other then that mostly stock
The coolent runs through the EGR spacer and not the TB. The purpose of the coolent lines is to cool the EGR spacer which is indeed a seperate piece and would lend considerable heat to the intake charge if not cooled. Also of note 93 cobras, and 94\94 GTs and cobras all have built in EGR spacers instead of seperate EGR spacers so they don't have nor need the coolent lines. The only difference between the built in EGR with no coolent lines and the Fox GTs with a seperate EGR spacer with coolent lines is the seperate spacer as all of the cars have TBs.
