  • SN95 4.6L Mustang Tech
Throttle cable ?
  • Thread starter Thread starter Conv99GT
  • Start date Start date Apr 1, 2005
C
Conv99GT
93
Montague,Mass.
Apr 1, 2005
  • Apr 1, 2005
Throttle body and cable?
Just got my car out from winter.InstalledAccufab plenum and FRPP TB and I have a s*&% load of slack in the throttle cable how do I get the slack out? I tried crimping some sinkers on the cable that hooks up to the gas pedal but that did not work they kept on coming off. so when I step on gas now I have no power because pedal is hitting the floor PLEASE HELP
C
Conv99GT
93
Montague,Mass.
Apr 1, 2005
  • Apr 1, 2005
someone please
white99gt
4,649
stockbridge,Ga(near atlanta)
Apr 1, 2005
  • Apr 1, 2005
Some slack is normal.The cable may not be routed right.
C
Conv99GT
93
Montague,Mass.
Apr 1, 2005
  • Apr 1, 2005
It's routed right the 70mm is different then stock where the cable goes around and there is alot of slack
C
chimchim
267
PA
Apr 1, 2005
  • Apr 1, 2005
There is a link on MustangWorld?. I just did this myself. Go to Home Depot and get a 3/4 inch long nylon spacer with enough of a hole to fit the throttle cable through. Cut the spacer long-ways with a hacksaw and slide it over the cable where the pedal and cable come together. After you slide it over, get two of the smallest hose clamps and put them overtop the whole damn thing and tighten them down (not ham-fist tight, but tight). WA-LA. Now, watch you don't snap your cable trying to smash it to the floor.
If you have any other questions, I'll be sober tomorrow morning.
twogts4us
4,188
12
79
Dunedin, FL
Apr 1, 2005
  • Apr 1, 2005
You've done something wrong here - there shouldn't be the slack you're describing. Did you route the cable the same way as the OEM TB? It goes underneath, around and up. I did this same swap without any cable issues - the only thing I can think of is that you've routed the cable improperly.
C
chimchim
267
PA
Apr 2, 2005
  • Apr 2, 2005
He probably did what I did. There is a hell of a lot of slack in all of our cables and when you change your TB or plenum, you get under there and check everything out and REALIZE just how much slack is in that thing. Then, it bothers you and you have to fix it.
here's the link: http://www.mustangworld.com/ourpics/fcar/99pedals.htm
It will work for any 94-04 muskrat!
SilverGTV8
295
West Brookfield, MA
Apr 2, 2005
  • Apr 2, 2005
Yes the pedal mod works well. The stocker has a lot of slack in the cable.
I did the mustang world mod, but the length had to be modfied to work on '03 GT. I shortened it so that under light braking the gas pedal is at the same level as the brake pedal to make Heel-Toe easier.
mustang90
1,209
15
58
Apr 2, 2005
  • Apr 2, 2005
Instead of clamps I used zip ties.
C
chimchim
267
PA
Apr 2, 2005
#10
  • Apr 2, 2005
  • #10
I filled the nylon spacer wit glue before I put it on. Dat bish is never coming off!
C
Conv99GT
93
Montague,Mass.
Apr 2, 2005
#11
  • Apr 2, 2005
  • #11
nope nothing wrong on it, it is routed correctly and alot of slack. the throttle arm is different on the stock then it is on 70mm or not so much the arm but where u go underneath around and up
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Engine 86 GT heavy throttle pedal
  • 86 Convert
  • Sep 4, 2025
Fox 5.0 Mustang Tech Sep 4, 2025
86 Convert
