Throttle doesn't close all the way
  • Thread starter Thread starter No.11
  • Start date Start date Dec 24, 2010
No.11
614
10
48
Los Angeles
Dec 24, 2010
  • Dec 24, 2010
The other day I removed the throttle body and cleaned the whole thing plus the IAC with carb cleaner. After I put it back on, I set the base idle but after giving it throttle I guess it stays stuck open a little bit. I have to push it with my finger to get the idle to drop and then it'll only stay until I open the throttle and then it sticks again. Any recommendations on what I can do? Maybe something to do with that spring underneath? Or I didn't dry it well enough? Thanks.
seijirou
2,417
DFW
Dec 24, 2010
  • Dec 24, 2010
That's a strange one.
Do you have the same problem with the throttle and cruise control cables disconnected?
No.11
614
10
48
Los Angeles
Dec 24, 2010
  • Dec 24, 2010
I'll check on that.
No.11
614
10
48
Los Angeles
Dec 24, 2010
  • Dec 24, 2010
problem is fixed. I took the throttle body off again, being careful not to destroy the gasket I just bought a few days ago. I played with the mechanism and noticed it was scraping on one side. I guess I had left some residue on there that was making it stick. so, I sprayed it down with wd40 and scrubbed it real good with an old toothbrush (screw the protective coating). after that, throttle action was super smooth! problem fixed, throttle goes where it needs to be. I was already thinking of just replacing the throttle body altogether. good thing I didn't. I'll wait til I have a gt40 tubular and some gt40 heads and get a 70 mm.
seijirou
2,417
DFW
Dec 25, 2010
  • Dec 25, 2010
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Engine Throttle sticking
  • Magnet86
  • Feb 5, 2025
Fox 5.0 Mustang Tech Apr 1, 2025
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
