throttle spring help
68blackv8
34
dont really know how to askthis so...'
right now my throttle spring (spring that allows the carb butterfly valve to close backup after pushing the accelorator pedal) has no mount. the spring is strecthed forward and hangin on a hole on the engine block. what is the spring supose to be attacthed to? i can get pics if you still dont know what i mean
thanks
for a 68 mustang
That's why I never liked looking at a stretched spring, made to fit where it's not supposed to.
A proper mount is the key.
I suppose you could fab a bracket to the carb mounting bolt.
you can kinda see what i did on my old motor. just a bent piece of metal with a hole drilled in it :)
The double spring is a spring inside a spring. It should also be mounted to pull in the direction of the cable or rod to close the blades, NOT forward. A double spring is mandated on some classes...not all. Keep from over stretching the springs as this will prematurely wear out the bushing in the carb body.
two springs, one in case the other breaks.
You don't need a stuck wide open throttle!
