- Jul 17, 2016
- 7
- 0
- 1
Okay I did some digging but didnt find anything of use. I recently got a 99 gt with 91k miles on it. All original except for a few things, in excellent condition. Im confused on a few things. I reset some codes the other day and theyre back. Theyre P0171 and P0174. They state that both banks are running lean. I also have a code for P0442, something about an evaporative emissions control leak. Could this one be related to the other two? Also, if it helps... the car has a brand new intake manifold, new cold air intake, new plugs, and new accel coil on plugs. i noticed a hose was pinched under the coil pack mounting bracket where it meets the throttle body. I believe it was the pcv hose? Its an elbow directly under the iacv. I replaced the hose with a new one and re routed it so it wouldnt pinch. I had a stumbling idle and occasional die after a warm start here and there. I dont know if it still exists or not because i havent drove the car since the new hose. But anyway, is any of this in relation to each other? Any help is appreciated. Thanks!
