I have a '94 GT with the 5.0 and my friened who had it before me says he put a Cobra pressure plate in it. the throwout bearing has been changed twice in the last 4 months. Could it be the Cobra pressure plate making them go so fast?
I just got the car a few weeks ago so I dont know about the clutch adjustment. And Im pretty sure they bearings were bought from a part store like Auto Zone. And thanks for typing in all caps. It really helps to get your point across. And how do I go about checking the clutch adjustment?bill302 said:WHAT KIND OF CLUTCH ADJUSTMENT DO YOU HAVE THIS MAY BE YOUR PROBLEM (CLUTCH ADJUSTMENT) AND WHERE ARE YOU GETTING REPLACEMENT BEARINGS FROM.
Thank you. I have a feeling that time will be pretty soon. How do I check to make sure that the cable is adjusted properly?urban96 said:improper cable adjustment can cause them to go bad fast. also might wanna change the bearing retainer on the trans next time you have it out
The Green GT said:And thanks for typing in all caps. It really helps to get your point across.
I don't know if that was meant to be funny, but it was to me!
It was more of a sarcastic funny, but anyways, I dont think its even been 5,000 since we changed it the first time.CManT1914 said:I don't know if that was meant to be funny, but it was to me!
FWIW, throwout bearing are ALWAYS going bad in mustangs. My friend replaced his throwout bearing, 5k miles later it was chirping again.
For a stock quadrant/pawl, pull up on the clutch pedal to adjust it.ROLLIN5.0 said:Mine does the same thing. When it started, I could keep it quiet by resting my foot on the clutch pedal, so I know it's the adjustment (lack thereof). Nowadays it is much much worse. Here's the question of the day. How do I adjust it?
Brandon
Im from Opelousas, its about 20 minutes from Laffayette and about 1.5 hours from Baton Rouge. I vist BR often though.sage2k said:
I run their single-hook and extreme FWA (and stock cable) on the fox. Not that it helps you much with the SN though.Ram000 said:thanks for the advice, rj, but i'm not planning on replacing the cable. what do you think of upr's quadrant?
