  • 2.3L (N/A & Turbo) Tech
throwout bearing squealing?
  • Thread starter Thread starter Asha'man
  • Start date Start date Jun 17, 2004
Asha'man
1,909
Denver
Jun 17, 2004
  • Jun 17, 2004
As of last night, I have a quiet but noticeable high-pitched squealing noise when my car is running, both in neutral and in gear. It disappears as soon as I push the clutch pedal slightly in. Think it's the TOB? I've heard a shot of white lithium grease into the bellhousing onto the TOB will fix that. I wanna get this done ASAP because I'm driving three hours to the Rocky Mountain Mustang Roundup tomorrow, and this is gonna bug me.
Just what I need, another crazy engine sound.....ticky lifters, whiny power steering, and now this.
Ash
kiddiccarus
The first widely accepted Tranny
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
Jun 17, 2004
  • Jun 17, 2004
Sounds like if you have a vibrating exhaust you can start a band with all of that.
140cilx
2,385
GA
Jun 18, 2004
  • Jun 18, 2004
yeah it sounds like the TOB. Mines a bit noisy in the SVO and does as you've described. I don't think you can actually lubricate the bearing inside the TOB race by shooting lithium at it from the clutch fork opening. And you might get some splash on your clutch pressure plate so be careful trying that.
You'll probably need to break down and do a 2 hour job dropping the tranny, replacing the bearing, lifting it back in. It's not hard at all.
GTPhreak
5,505
Rowlett, TEXAS
Jun 18, 2004
  • Jun 18, 2004
my throwout bearing is chirping too. the way i see it, its not hurting anything, and its not bothering me too much so its staying in the car
mr_woodster
1,314
Riverside, CA
Jun 18, 2004
  • Jun 18, 2004
I just replaced mine last week, quiet as can be(besides the power steering and ticking lifter(s) ). When u do the change, make sure to grease everything except the clutch and flywheel or else your gonna be back there real soon.
Everything includes the main shaft where the bearing resides and teh little swivle ball deal that the fork balances on. Also , to get the fork out you hafta remove the linkage from it...
Tip: when you put it back make sure everything is taunt (IE:the little metal ball at the end of the cable in its holder) before you try to connect clutch cable.
K
ka0tyk
1,610
Los Angeles, CA
Jun 19, 2004
  • Jun 19, 2004
on my old 2.3 I forgot to lube the front bearing retainer and the TOB was chattering on it... spraying it with some lube helped, but then i started having to do it like every oil change... annoying as hell...
saleenx029
117
Cincinnati, Ohio
Jun 28, 2004
  • Jun 28, 2004
Fix that SOB TOB, mine went out and it did damage to the fingers to my clutch, don't wait too long mine exploded. Bad news
Asha'man
1,909
Denver
Jun 28, 2004
  • Jun 28, 2004
Adjusted my FWA because my gears weren't engaging right (cable may be stretched or something, I dunno) and now the TOB doesn't squeal anymore. I'm beginning to fear my driveline right now....I have a bad feeling that something major is gonna blow as soon as I drop $350 on tires this week.
Ash
another throwout bearing question
  • bsedwebt70-5.0
  • Jul 9, 2010
7K
Fox 5.0 Mustang Tech Jul 12, 2010
bsedwebt70-5.0
Loud squeal when clutch pedal pushed in, throwout bearing?
  • Chythar
  • May 27, 2009
  • 1994 - 1995 Specific Tech
37K
1994 - 1995 Specific Tech Jun 7, 2009
Chythar
86-95 5.0L Clutch Swap Help
  • 5spd GT
  • Jun 21, 2007
15K
Fox 5.0 Mustang Tech Jun 10, 2009
oldskolbus
M
  • Murf01GT
  • May 4, 2004
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech May 9, 2004
kennym01
K
Common clutch part numbers and clutch installation write-up
  • 5spd GT
  • Apr 8, 2005
6K
1994 - 1995 Specific Tech Apr 8, 2005
5spd GT
