I just got my car going again yesterday after my winter project-pulled the engine, replaced all gaskets + seals, cleaned/painted engine and all accesories, repolished my upper intake, valve covers and belt tensioner, cleaned up the engine bay, new T/O bearing, and most importantly, installed my Thumper heads and TMoss ported lower intake. Car already had a Comp cam in it (can't remember specs from memory right now) and its alive again!
My valvetrain is a little noisy yet, when I set up the rockers they all took almost exactly one turn to get to 18 lb/ft, so I have a shim kit on the way to re-set up the rockers again. Still need to fiddle with the fuel pressure and ignition timing a little bit, but I'm happy!
I was gonna get a new short block,but I think I'LL push my luck with the original !! Did you take it out for a spin? How did it feel?
