tick tick tick
  • Thread starter Thread starter green
  • Start date Start date Jul 30, 2004
green
291
  • Jul 30, 2004
this is annoying, what causes this ticking sound? lifter, pushrod, rocker arm. it only lasts for a couple of minuts then goes away. it only does it on start ups. dosent mater if its hot or cold it still does it. maybe its dry of oil but i cant see it cause you can drive it for and hour shut it off start it up then its back. new lifters a couple years ago stock pushrods and stock roller rockers.
mustangsquared
828
new bern nc
Jul 30, 2004
  • Jul 30, 2004
throw out bearing?? Could be a push rod...if it is spinning in it guide it may tic until it turns to a point where it catchs (IE slightly bent???). Just a few random thoughts. RR tapping on the valve cover? Mine did that...had to tap them out a little with a hammer.
Jo_885o
422
Clint. Twp, Michigan
Jul 30, 2004
  • Jul 30, 2004
Ck oil pressure. Mine did that when stock and my oil pump driveshaft took a dump.
HISSIN50
34
129
Jul 30, 2004
  • Jul 30, 2004
dont overlook exhaust leaks too.
T_5.0_N'works
260
Texas
Jul 30, 2004
  • Jul 30, 2004
Could be a lifter, the injectors, but I'd say 75% of the time it's an exhaust leak.
IndyBlk5.0
1,122
New Whiteland, IN
Jul 30, 2004
  • Jul 30, 2004
yeah exhaust leak probably.
green
291
  • Jul 30, 2004
its a carburated car an 85gt. its definatialy not the exaust, its inside the engine, driver side.
1fast94svt
205
Michigan....Detroit
Jul 30, 2004
  • Jul 30, 2004
could be t/o bearing, exhaust leak or blown head gasket. Hope not for the blown HG. I have one and its $$$$ to fix, or do it yourself and be prepared for a headache unless you are a real good machanic.
dastang2
2,020
tx
Jul 30, 2004
  • Jul 30, 2004
how can it be an exhaust leak, it only does it at startups, i had a car that started doing that, main bearings are going or the oil pump is weak
T_5.0_N'works
260
Texas
Jul 30, 2004
#10
  • Jul 30, 2004
  • #10
Start ups? When metal get's hto it expands, closing the minor gap in where the exhaust leak is. Start up, my Pathfinder has bad lifters, ticks for about 3 seconds on start up in the morning and I never here it again...
dastang2
2,020
tx
Jul 31, 2004
#11
  • Jul 31, 2004
  • #11
then i have a major exhaust gasket leak on all my 95 then. i have never seen an exhaust leak close up after warmed up. mine stay there till i kill it.
5.0_Gil_89
163
Germany
Jul 31, 2004
#12
  • Jul 31, 2004
  • #12
Check the header collectors if you own Mac shorties. A friend of mine held his up in the light and where the tubes meet the h-pipe flange holes everywhere. I've been chaseing an ext leak for a while that's the first place I'll look next week when I take it to the hobby shop.
green
291
#13
  • Jul 31, 2004
  • #13
no its under the valve cover, not an exaust leak, like buddy said if it were an exaust leak it would do it all the time and not just on start ups. main bearings is definatly to low for this sound. the sound is like in the middle to the top of the engine.
green
291
#14
  • Jul 31, 2004
  • #14
oh ya, it dosent do it all the time either, just once in a while
D
dude5l
201
Grande Prairie, Alberta , Canada
Jul 31, 2004
#15
  • Jul 31, 2004
  • #15
You may need to adjust the rockers.
dastang2
2,020
tx
Jul 31, 2004
#16
  • Jul 31, 2004
  • #16
rockers on E7 heads are non adjustable. check you lifters.
green
291
#17
  • Jul 31, 2004
  • #17
its an 85gt so it dosent have e7 heads. it has e5 heads. but i dont think you can adjust them either just tightn them down
dastang2
2,020
tx
Jul 31, 2004
#18
  • Jul 31, 2004
  • #18
yeah my bad, i think you only torque them to 17-27 pounds.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Lifter tick
  • Creomod
  • Oct 31, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2024
Creomod
