ticking from valve covers
  • Thread starter Thread starter sennf1
  • Start date Start date Aug 12, 2006
sennf1
detroit
Aug 12, 2006
  • Aug 12, 2006
I built a 302 with ford roller lifters and scorpion roller rockers with trick flow alum heads. The engine has ticked on both side since I started it. I have adjusted the rockers about 5 times now. I have talke to trick flow and scorpion. Would the side to side slop in the rocker be that noisy or I have read that some guys have put in different oil. Or maybe low oil. I am thinking of pulling the intake and checking the lifters, and then adjusting the valves again. please help
pb_paulie_b
894
Chaptico, Maryland
Aug 12, 2006
  • Aug 12, 2006
Are you using stock valve covers? They could be hitting/rubing on the valve cover.
fidstang
307
South Lansing
Aug 12, 2006
  • Aug 12, 2006
stud mount rockers will be noisy when compared to the pedistal mount. Took me a while to get used to how loud mine were. I have new lifters.
blue92lx
14
  • Aug 13, 2006
I have pedestal mount rockers and they tick too. It's normal, as long as it's not excessive don't worry about it. They ticking may also be louder or quieter at different RPM's. For example, mine tick the loudest at 2000 RPM for some reason, then they get quiet above or below 2000 RPM. It's normal though, if it's really loud it may be hitting the valve covers like mentioned above, or you got a bad lifter. It's up to you to determine if you really want to go through the trouble of changing lifters. It's a pain and takes a while to do all the work.
slow5.0gt
138
  • Aug 13, 2006
my z28 has a 454 and had that ticking problem I used too light of an oil switched to a heavier type 30w50 fixed it right up
DJTR
228
OTTAWA, Ontario, Canada
Aug 13, 2006
  • Aug 13, 2006
if you are sure it is not rubbing on the valve covers and the slight tick is really driving you insane, get some LUCAS God I Love that Stuff!
sennf1
detroit
Aug 13, 2006
  • Aug 13, 2006
:SNSign: I have ford racing valve covers, and I checked and they are not hitting. I will trying to adjust them again like scorpion said, change the oil and put a little lucas in and see what happens. Thanks everyone and I will let you know what happens.
pb_paulie_b
894
Chaptico, Maryland
Aug 13, 2006
  • Aug 13, 2006
sennf1 said:
:SNSign: I have ford racing valve covers.
Well why didn't you say so
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
C
Valve stem tip tap?
  • Coolen
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 14, 2025
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
