Thenemesis
well.. how long have you had those heads? have you ran your car hard and got it really hot at all?
Thenemesis said:well.. how long have you had those heads? have you ran your car hard and got it really hot at all?
and the sweet being the satisfaction of fixing them.
Alright, I am done rambling......for now.feifong said:this might sound stupid but check the clutch cable near tranny might be loose or u might need a new one this is happening to me dunno might be a different thing
Thanks for the tip though, never heard of that.ExplodingGopher said:I have the same thing, its a bad lifter. It just started ticking loudly one day when started, and it got louder as it got warmer, tried oil detergents to try and fix but you never know, maybe the spring that holds the actual lifting part that pumps up came out. I don't feel like taking the intake off and stuff, so the 5.0 is grounded until new engine is ready.
I am debating just taking off the intake and putting new lifters in it, but then what if it is a pushrod, or rocker. I can't afford to buy all new lifters, pushrods, and rockers. Will it hurt anything if I keep driving on it?
Both times it really sounded like lifter noise, so check for leaks carefully before you go tearing you motor apart. You may also want to buy/borrow/steal a stethescope and try to narrow down where it's coming from.. works with a long bladed screwdriver, too. Good luck.-86GTStang said:..sorry to hear about your problem. I just installed a set of new FelPro exhaust header gaskets, because of ticking sound.. BUT, just want to say that you can use a brass,copper,etc metall pipe, approx 25-30inch long, and diameter around 0.5inch as a perfect tool for finding were your noise come from.Put on one layer of T-shirt cotton etc on one end, for protection of your ear, and then you got yourself a nice "doctors tool". Start listening to your valvecovers, exhaustports etc, by pressing your "tool" against the engine... GOOD LUCK !
Ranchero5.0 said:Before you flip out too much just pop the upper off and the valve cover and check each rocker for looseness on that cylinder's firing point on the distributor. Pull the cap and mark the distributor cup with the cylinder numbers, then bump it around to each position and check it out. I very seriously doubt it's a collapsed or failed lifter, most likely it's a loose rocker. What brand did you use? I've seen the pushrod beat up through a set of proforms on a customers car for no good reason.
Jamie
William741 said:Just thought I'd throw in my experience. I just installed twisted wedge heads w/ the trick flow rockers. After adjusting the rockers, everything was quiet for about the first 10 miles, now it clicks(audible inside car at idle) out of both valve covers. I know its adjusted correctly, and i tightened down all the poly locks, so im just wondering if maybe this a normal noise? See ya, Will
I have a bigger problem now, my tranny just went south.
One thing about owning a fox body, you couldn't really get bored for too long, because there is usually something that could be fixed, prevented, or upgraded. Maybe I'm just picky. sounds like a header leak tip of the day buy you some MR gaskets soak them in water for one hr to where they expand and while they are soaked put them on, and start the 5.0 they will steam alot but thats cause they are cureing and i bet that will salve problem thanks Leo no more leaksRock777 said:I can't figure how this would cause this sound or why it would get louder when warm. The cable is almost new, but that doesn't mean everything. Also, the ticking is there whether driving, revving in neutral, or revving with clutch pushed in.Thanks for the tip though, never heard of that.
5.0 coup said:sounds like a header leak tip of the day buy you some MR gaskets soak them in water for one hr to where they expand and while they are soaked put them on, and start the 5.0 they will steam alot but thats cause they are cureing and i bet that will salve problem thanks Leo no more leaks
