- Nov 12, 2002
- 270
- 26
- 29
Hi,
My 95 was sitting idle for many many years.
the brake rotors were really rusty. calipers were rusty but not as bad as the rotors.
i cleaned one of them and it is all pitted. Havent checked the others yet, but i assume they will be as bad if not worse.
So, at a minimum, i want to replace all 4 rotors.
found this on lmr https://lmr.com/item/LRS-61041-KIT/mustang-drilled-slotted-brake-rotor-kit-9404
decent enough? is there something better i should consider? stock rotors from autozone range from $42 to $59 each, so this seems like a fairly decent deal.
is it safe to assume that if later i want to upgrade the calipers, i wont need to buy another set of rotors?
current plan for car is to just get it back into good shape and maybe work on 1/4 times. maybe put supercharger back on it. i had the car as is but with the charger on it and stock brakes, never had any troubles (but i may not have been aware i had troubles).
i think i recall back in the day about people getting larger diameter rotors (but i could be wrong), i guess that would involve some type of conversion kit? i dont think i want to get into that at this time, but i could be swayed.
thanks
thanks
