time to do timing
  • Thread starter Thread starter shttygtstang
  • Start date Start date Nov 25, 2004
shttygtstang
978
  • Nov 25, 2004
ok when timing it should i time it from btdc or atdc and what range of timing should i be in .16* 18* with the spout out thanks
Motorhead6T5
215
Marysville,CA
Nov 25, 2004
  • Nov 25, 2004
Are you running boost timing retard? If you have a supercharger I wouldn't run the base timing that high without one.
shttygtstang
978
  • Nov 25, 2004
thtas what im trying to figure out what degree would be best and should i set it at atdc or btdc on the balncer
Motorhead6T5
215
Marysville,CA
Nov 25, 2004
  • Nov 25, 2004
How much boost?
shttygtstang
978
  • Nov 25, 2004
14 psi . do i set the timing from atdc or btdc on the balncer
C
crunchie12268
599
Manhattan, KS
Nov 25, 2004
  • Nov 25, 2004
I thought it was btdc
shttygtstang
978
  • Nov 25, 2004
also do i use the eye on the left of the balncer or the pointer right above the balncer
C
crunchie12268
599
Manhattan, KS
Nov 25, 2004
  • Nov 25, 2004
I thought it was the pointer, if not than I am ****ed.
shttygtstang
978
  • Nov 25, 2004
ttt
Rick 91GT
Mustang Master
95
99
PA
Nov 25, 2004
#10
  • Nov 25, 2004
  • #10
IF you are looking at the balancer you look a the number to the right on TDC, set it to 10 degrees base (mark it with a sharpie or paint) with the spout out, you use thr sharp edge of the pointer.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
