Time to rebuild the AOD
  • Thread starter Thread starter RYC CUKR
  • Start date Start date Feb 12, 2006
RYC CUKR
1,437
Orlando
Feb 12, 2006
  • Feb 12, 2006
Alright guys
The time has come to rebuild the AOD in my 93 GT and I am going to try to do it myself.
Here is the current condition of the trans. It has the stock converter and a Transgo shiftkit installed in it. And no OD. That is the main problem right now. With no OD and 4.10s it sucks a lot of gas and is a bear to drive on the highway. 3600rpm @65.
I am planning on getting an Edge converter but am not sure if I should stay lock up or go non lockup. The car is pretty much just a weekend car that seems to find its way to the dragstrip about every two weeks. Funny how that works. Any suggestions would be appreciated on what type of converter.
Since the OD band is shot I know that I am going to have to replace it and I figured that I would put an A+ servo in at the same time. What else do I need to look at/replace while I am working on the trans?
Since I have it out should I just go ahead and put in new clutches and basically rebuild the whole thing?
If so what type of clutches would be best?
Do I need a hardened input shaft? I do have a nitrous kit and at some point will probably go up to a 150hp shot.
I would like to get a lentech valve body and have the nice OD delete instead of the crappy stock shift pattern.
Any help would be greatly appreciated and any suggestions on specific parts or brands would be nice as well. If there is something major that I a missing let me know.
Thanks
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Feb 12, 2006
  • Feb 12, 2006
You pretty much answered your own questions. If you plan on more N20 I say get the hardened one pice input shaft,, if you don't mind loosing lock up. An good VB would be the way to go also. Alto red clutches, A servo, 2" kevalar OD band would be nice upgrades aslo. Plus if the $$$ permits,, get the 4R intermeditate presure plate so you can upgrade from 3 to 4 intermediate clutches. And get the upgrade on the direct drive clutches to the 8 clutch pack.
But if on a budget, a good rebuild kit, at mininum a hardened shaft(either to replace the direct drive shaft or a 1 piece) and the aftermarket VB would be the way to go with a good converter.
Check out this site for parts to get an idea. But these guys are pretty straight up, did order from them a coulple years back when freshing upp a buddies AOD.
RYC CUKR
1,437
Orlando
Feb 12, 2006
  • Feb 12, 2006
Cool.
At least I know that I am on the right page then.
I probably will go with the hardened 1 piece input shaft since it would really suck to rebuild it and then break it. Any recommendations on who makes a good hardened 1 piece input shaft?
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Feb 13, 2006
  • Feb 13, 2006
Lentech, Art Carr and TCi make one that I know of. Art Carr uses the c6 spline(26) count on theres so you will need one of their converters. TCI and Lentech use the 31 spline and have more varity of converters. But if you custom order a converter most good companies can make the converter for either spline count.
Dang forgot to aad the link in last post,,Sorry... But here it is.. http://www.ford-aode.com/
RYC CUKR
1,437
Orlando
Feb 14, 2006
  • Feb 14, 2006
Thanks for the info.
I am pretty mechanically inclined, have rebuilt a few motors and do almost all of the work on my 93 myself. With the help of a shop manual is this something that is pretty "do able" by the average backyard mechanic, meaning me?
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Feb 14, 2006
  • Feb 14, 2006
Oh yea,, But there are a few special tools you will need(to make the job smoother). Mainly the seal intall kit, and the clutch piston compressor. Check out that site above and it shows pics of the tools. Also get the ATSG manual and you should be good to go. There is a rebuild vid on Ebay. Not sure of its quality though, never seen it, just saw the ads for it.
If its your 1st tranny rebuild,, have a bench or work space big enough to lay out the parts in order that they come out. Then rebuild each drum seperatley and put it back in it's position. That way when every thing is done,, it will be in order but ready to go back in.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • brandyn200
  • Jun 20, 2026
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
