Time to replace the Valve Seals
vristang
4,933
101
124
Seattle
Well my valve seals are toast. :nonono:
I have decided to replace them myself, hopefully this weekend.
Any thoughts on valve spring compressors are welcome.
I have a C-compressor now, but don't feel safe using it.
I think I will buy a lever bar compressor locally.
Anyone have tips or advice? This is my first time :D
The heads are TrickFlow Twisted Wedge.
I have yet to hear back from TrickFlow for part numbers on the seals.
Should I plan on replacing the locks while I am at it?
Thanks Stangnet,
jason
c clamp compressor is the only thing I would use personally. Using them for the last 15 years. As for the valve seal they are Viton .500" I.D. x .700" O.D.x 11/32" stem ( TFS-51400454 ) As for the locks, thats up to you really. They are cheap.
Use Viton Seals on int and exh, and any local machine shop should have them in stock I think they are a .530" for an 11/32" valve. If you do not have a seal installer you can use a 12mm 12pt socket to push them done over the guides, use oil and the small plastic valve cover so you do not rip the seal.
Are the heads on or off the motor?
Locks are cheap I like to replace them, along with inspecting the retainers.
I was planning on pulling the heads. Right now the motor is running, so I can get to work. It will only take a few more hours to pull the heads.
Thanks for the dimensions for replacement seals. :nice:
Will most local parts stores have the seals I need, or will I have to go to a machine shop?
Maybe a dumb question - What is Viton? material, design type, or what?
I have been told positive seals are what I need, but found an old thread talking about umbrella seals.
Thanks again for the info guys
jason
Viton is a material, they should be a positive seal type... Just verify the guide size with TFS, but I am pretty sure the size I posted is correct.
I know my local machine shop stocks the seals, should be around $1.00-1.25/pc
I appreciate all the responses.
I called Trickflow and they were great. The techy that answered the phone new exactly what I wanted. When he found out I was in a hurry to get the job done he placed an order for me through summitracing to overnight them to my house. Pretty cool if you ask me. :nice:
He is shipping me a set of 16 positive Viton seals, part number 51400454.
Next Question...
Could I use my Leakdown test kit to replace the seals without pulling the heads?
Would this also help me determine if the valves are sealing well against the seats?
I should hear an air leak past a valve, right?
Thanks again for helping the valve seal rookie, :SNSign:
jason
One last bumpity bizump for the following...
Many thanks,
jason
Next Question...
jason
just like i told you in the second reply
vristang,
If you do decide to replace these seals on the car, you will have to regulate the pressure way down to prevent the engine from turning when applying the air. I had to go as low at 25psi to keep the engine from turning when the air was applied.
One thing you can do prevent the engine from moving is to use a breaker bar and socket on the damper bolt and wedge that against the frame each time you complete a cylinder.
If you don't want to use air you can always stuff some rope or string in the spark plug hole to prevent the valve from dropping.
Keepers are inexpensive. Just make sure you use hardened keepers.
:rolleyes:
Yep, you told me so.
"Neener, Neener" heard loud and clear. :p
Thanks again to everyone who chimed in.
I will try to come back an post some pics of the job for anyone who finds this thread on a search.
:SNSign:
jason
89SaleenGT said:
vristang,
Why not just let the motor kick over like on a leakdown test?
Again I am new to this task so you might have to use small words? :D
thanks
jason
