Once you deviate from stock throw the factory recommendations out the window. Every engine is different. Initial advance, vacuum advance, total mechanical, rate at which mechinical comes in - they all have to be experimented with to find the optimum.
Usually a bigger cam likes more initial (I run 15 degrees) and a fast advance curve. When you run more initial you usually have to restrict the mechanical advance to keep from having too much total.
