TIMING ADJUST CONFUSING
  • Thread starter Thread starter BAHRAINI_STANG
  • Start date Start date May 9, 2007
BAHRAINI_STANG
69
  • May 9, 2007
today i deside to adjust my timing but i was confusing how to do iy.
what the correct procedure for it.
what i did is put harmonic to tdc 0 degrres, then i put white marker in it to 14 ,warm the engine,remove spout,then timing ligth ,at this step i was confuse ,what should i do ,do i need to bring the 14 deg marker to pointer edge or theres diffrent method .
BAHRAINI_STANG
69
  • May 9, 2007
anyone.....
StreetDreamsGT
449
New Jersey
May 9, 2007
  • May 9, 2007
Now you turn your distributor clockwise to advance the timing so that the 14 degree mark lines up with the pointer.
vristang
4,933
101
124
Seattle
May 9, 2007
  • May 9, 2007
Here is a link that may help...
http://www.muscularmustangs.com/timing.php
You only need to loosen the dist. hold down bolt enough to allow rotation.
Some motors can't take 14*
and other can
It can take some trial and error to find out what the motor is happy with.
jason
BAHRAINI_STANG
69
  • May 9, 2007
the problem i dont have timing pointer so i will go to junkyard to take one ,is all 5.0l timing pointer are same non ho.
when i install it do i need to find tdc first
vristang
4,933
101
124
Seattle
May 9, 2007
  • May 9, 2007
All the timing pointer on 5.0's *should* be the same.
Still, it would be good to 'calibrate' the pointer by setting #1 at TDC.
That way you will know it is right.
Good Luck,
jason
StreetDreamsGT
449
New Jersey
May 9, 2007
  • May 9, 2007
make you a deal, I don't have one either..... lol so if you grab one up for me i'll gladly pay you and the shipping to send it to me. I'm unsure but i'd guess the ho and non ho are the same. Yea you need to bring the number one piston to top dead center and when installed the pointer on the timing mark should line up with the 0 on the harmonic balancer.
90blacknight
136
May 9, 2007
  • May 9, 2007
Isn't this guy in Bahrain? They have 5.0's in junkyards in Bahrain?
BAHRAINI_STANG
69
  • May 9, 2007
yup we have but rarly you find a mustang so i will go for non ho engine if my luck bad
4G-KDMP
935
CA
May 9, 2007
#10
  • May 9, 2007
  • #10
why not buy it and have ship it direcly to your house?
http://www.50resto.com/products.aspx?searchkey=6023A
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • dan50
  • Jul 18, 2026
dan50
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
