  • 1994 - 1995 Specific Tech
timing advance help continued
  • Thread starter Thread starter 302fordracer
  • Start date Start date Apr 8, 2004
302fordracer
738
Vancouver, WA
Apr 8, 2004
  • Apr 8, 2004
someone on here said that after advancing the timing on the 94-95 gt that you would have to use higher octane gas.....is this really true because my buddy who was a mechanic for years says no....what is you guys' experience? If higher octane is required will 89 or 92 suffice, if so which is prefferred?
1hot5.0
1,615
Surprise, Arizona
Apr 8, 2004
  • Apr 8, 2004
Yes you will have to run higher octane whenever you advance your ignition timing. Failure to do so will result in pinging.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 8, 2004
  • Apr 8, 2004
i guess you could just advance it with 89 in your tank (if you even can) until it starts to ping. You dont HAVE to run a higher octane of fuel but a higher octane allows you to further advance the timing.
I run 93/94 whatever i can get my hands on and my timing is at 16* with no pinging
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
