timing at advanced 24 help
  • Thread starter Thread starter murphmaster5
  • Start date Start date Oct 22, 2005
M
murphmaster5
115
PA
Oct 22, 2005
  • Oct 22, 2005
my car runs realy good but wen i set the timeing for ad 14 degrees put the chip back in and tighten dis bolt then start it up and recheck the timing its at advanced 24 degrees at idle. I prety sure im doing the timing right i set the gun for 14 ad then point at zero on dampner right
sunil6784
620
Boston, MA
Oct 22, 2005
  • Oct 22, 2005
You probably are doing it right-after you put the spout connector back in, the computer will advance the timing. I never use the advance, I just keep the advance at zero and turn the dizzy until it gets to the markings I want...
HISSIN50
34
129
Oct 22, 2005
  • Oct 22, 2005
It is normal for the computer to advance timing 10* just from putting the SPOUT back in.
You can also paint the 14* line on your balancer and set your timing light to 0 and time it that way. Some guns are not very accurate (not that yours isnt - mine is off by a degree or two).
And another tip: set your timing with the SPOUT out. Then tighten the dizzy hold-down bolt. Then recheck it - the dizzy can rotate as you tighten the hold down and will change your setting a degree or two.
Good luck.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Oct 22, 2005
  • Oct 22, 2005
Yep, what they said.
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
9
I just put a new engine in need help with setting timing through mega squirt tuner Studios.
  • 90 LX Vert 347 MS
  • May 23, 2025
Digital Self-tuning Forum May 24, 2025
Glliw
G
