timing chain vs timing gear drive
  • Thread starter Thread starter BrownPSU78
  • Start date Start date Dec 21, 2005
BrownPSU78
129
Dec 21, 2005
  • Dec 21, 2005
so i am building a 393\408 stroker I am making a parts list...I have seen the gear type timing mechnasisms and the timing chains...The (not so)cheap gear drive from summit is "noisy" and 175 dollars....the cheap timing chain set is like 28 bucks with the summit model at 70 dollars...Now the gear drive has a total of 7 degrees of adjustability I think, I assume is a lot stronger, and gives the "classic gear whine"....My question is what is the difference in application use...I saw this a while ago and always thought it was kinda cool...but is it worth it?What are the Real benefits? and what exactly does this "whine" sound like ?
--Brown
Route666
1,652
Brisbane, Australia
Dec 21, 2005
  • Dec 21, 2005
I've never really heard it (in person anyway) but I'd say imagine a worn out second gear on deceleration (you know the kind of whine) but perhaps quieter and attached to engine rpm, not vehicle speed.
I like the whine, but extra noises, especially whines can be seen as worn out noises, and it isn't necessary unless you're racing fulltime.
I've always thought the advantages of them is that they will handle higher rpms, but the ones I have seen advertised usually say that they are not for over 7krpm.
They're apparently more sturdy, but how frequent are timing chain failures?
I wouldn't like to say which one is more efficient, because the gears are bigger, but the chain has mass not only going in circles, but following the chain path, not to mention all the joints in the links. If you're after efficiency though, go for a dry belt setup.
Gear drives apparently don't go together with knock sensing fuel injection equipment, as it can give a false reading, by the teeth meshing I assume.
I'd say the general consensus is that gear drives aren't worth the effort unless the engine spends 50% or more of its time at high rpms.
jes72mustang
224
S. Central PA
Dec 21, 2005
  • Dec 21, 2005
A friend of Mine has a gear drive set-up in his Pick-up and My F-I-L is installing gears in his Small block S-10. The sounds can be mistaken for a supercharger. It really is a neat sound. I have been contemplating going with gears on my stang as well. Look forward to reading other opinions.
LMan
1,246
Mom's basement
Dec 21, 2005
  • Dec 21, 2005
Gear drives are noisy. I personally would not want my engine whining like a blower if I did not have a blower to back it up, but others feel differently, I am sure.
At anything up to hardcore racing RPMs, you are paying extra for the whine alone. A good-quality double-roller tming chain set is all but foolproof.
rbohm
6,698
550
204
tucson,az
Dec 21, 2005
  • Dec 21, 2005
:Teh-Win:
i also prefer using a good roller chain to gears.
thehueypilot
1,084
Medina,Tennessee
Dec 21, 2005
  • Dec 21, 2005
My 4 X 4 has an all gear transfer case and if I took you for a ride in it around the block you would understand better why they went to chain drives. ITS LOUD!
iskwezm
4,159
20
79
Rowland Heights,California
Dec 21, 2005
  • Dec 21, 2005
A Ford gear drive is A LOT different then a chevy,so dont be confused if you think a Ford will sound the same,due to its cast timing cover,it gets muffled a lot.I have a Pete Jackson "noisy" in mine and it not "that" loud.It sounds nothing like a "worn out" part as people have said.My buddy has a Pete Jackson "quiet" which uses angle cut gears and his is BARELY louder then a belt whine.I personally like it and everybody that hears it likes it.I will say that a Chevy "noisy" can be hearda few blocks away.
BrownPSU78
129
Dec 21, 2005
  • Dec 21, 2005
So for me there is no reason for it unless I want to spend for sound...why did your buddy decide to get one and go with the "quiet" kind...hey ISKQEZM do you think you could take a sound clip of the whine by chance?? thatd be sweet..if not its cool...thank you
--Brown
iskwezm
4,159
20
79
Dec 21, 2005
  • Dec 21, 2005
--Brown
he thought the "noisy" would be too loud,he was actually dissapointed in the quiet.
If i knew how to put up a sound clip i wouldamnit:
10secgoal
2,801
San Diego
Dec 21, 2005
#10
  • Dec 21, 2005
  • #10
They are nice in the fact that they do hold the cam timing longer than a chain. A chain will stretch over time throwing off the cam timing. But more than likely the chain will out live your motor anyways.
BrownPSU78
129
Dec 22, 2005
#11
  • Dec 22, 2005
  • #11
okay so i can forget about buying one...hehe i just got ISKQEZEMs name....
--brown
iskwezm
4,159
20
79
Dec 22, 2005
#12
  • Dec 22, 2005
  • #12
--brown
it takes a while and i bet you a lot of people still dont get it
69Rcode_Mach1
1,473
Salt Lake City, Utah
Dec 22, 2005
#13
  • Dec 22, 2005
  • #13
Wow I never understood your name either, I never thought of it being something like that. Very clever....... and now I have contributed.
jerry S
1,365
52.22N 5.12E
Dec 23, 2005
#14
  • Dec 23, 2005
  • #14
jes72mustang said:
The sounds can be mistaken for a supercharger. It really is a neat sound. .
Once the ricers hear about this side effect, a gear drive will be the newest "must have" in the Honda ranks.
69Rcode_Mach1
1,473
Dec 23, 2005
#15
  • Dec 23, 2005
  • #15
No way Jerry a gear drive atleast serves a purpose. They don't pay for anything useful, now if it were a cd of sound effects they would be all over it.
iskwezm
4,159
20
79
Dec 23, 2005
#16
  • Dec 23, 2005
  • #16
not gonna happen,they have timing belts
but some fool did make a exhaust tip that was banned from certain cities for haveing a "whistle " noise when it was revved.
ashford
485
fargo ND
Dec 23, 2005
#17
  • Dec 23, 2005
  • #17
gears hold a time better than a chain, it dont stretch. also it helps with harmonics.
muffler bearings!?!?!
http://www.mufflerbearings.com/
65stang289
922
Fort walton Beach FL.
Dec 25, 2005
#18
  • Dec 25, 2005
  • #18
Is there a down fall to these at all. If some thing breaks wont it eat everything alive in the motor. It might be a dumb question I dont know just asking?
LMan
1,246
Mom's basement
Dec 27, 2005
#19
  • Dec 27, 2005
  • #19
wha?
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
