Timing chains and eccentrics
  • Thread starter Thread starter pazur
  • Start date Start date Nov 26, 2007
P
pazur
82
northern Virginia
Nov 26, 2007
  • Nov 26, 2007
Timing chains for sbf are designed for 1-piece or 2-piece eccentrics. Are these somehow interchangeable with little machining work, especially when replacing 2-piece ecc. timing chain with one-piece?
D
D.Hearne
11,730
south louisiana
Nov 27, 2007
  • Nov 27, 2007
There were three eccentrics used, too are thin, )one each cast iron and stamped steel 2 pc) Then another thicker eccentric. The cast eccentrics need a longer dowel pin that extends farther out from the cam gear to engage the eccentric. The 2 pc has a bent tab that engages the cam gear hole. As far as replacing one with the other for durability's sake, the 2 pc it seems would be the weaker of the two, but I've never seen or heard of either failing. They seem to last longer than the engine.
P
pazur
82
northern Virginia
Nov 28, 2007
  • Nov 28, 2007
I was asking because I bought a timing chain, and tech support guy told me that for '73 sbf I needed timing chain for 1 piece eccentric (up to 1984). Timing chain's instructions however say that ford ended up with with one-piece eccentrics in '72, so I would actually need chain for 2-piece ecc. I just wanted to know if there is any way to adapt timing chain with 1-piece ecc where chain for 2-piece ecc should be once I get to actual instalation. Well easiest way is to buy both chains; maybe I'll do it to be sure
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Need urgent help. Timing chain sprocket. VIDEO..
  • 2003 mustang gt modded
  • Jun 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
Timing chain tensioner? (youtube video link)
  • slxne5.0
  • Sep 7, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 7, 2025
slxne5.0
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 5, 2025
