Timing Cover Gasket Questions
  • Thread starter Thread starter 7upstang91
  • Start date Start date Nov 10, 2009
7upstang91
936
124
74
Florida
Nov 10, 2009
  • Nov 10, 2009
I am in the process of replacing all the gaskets on the timing cover. How do I take the center one out? the little round one that is around the crank and the harmonic balancer? Any other tips I should know why I'm down there?
Thank you!
lancec2c30
570
Washington
Nov 11, 2009
  • Nov 11, 2009
I knocked mine out with a punch and hammer. Be careful not to damage the timing cover itself any. Just work your way around it until it finally comes loose.
When installing the new one, it's best to find a socket or something similar that is the same diameter as the seal. That you can use to drive it in the timing cover.
ID89GT
1,659
18
49
Spokane Valley, WA
Nov 11, 2009
  • Nov 11, 2009
I used a seal puller tool, was pretty easy to do
7upstang91
936
124
74
Florida
Nov 11, 2009
  • Nov 11, 2009
Thanks guys. Any tricks to putting the timing cover back on? I seem to be having some trouble.
W
wv109323
100
Lenore ,WV
Nov 11, 2009
  • Nov 11, 2009
Timing cover
Use silicon sealer( the blue is called Smurf Glue) between the Timing cover and the oil pan gasket. Make sure you do not rip or tear the oil pan gasket(especially if it is a rubber oil pan gasket) when installing the bolts up through the oil pan.
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Nov 11, 2009
  • Nov 11, 2009
Thank you!
Once I got the old one knocked out, I took it and flipped it upside down and used it to tap the new one in.
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Nov 11, 2009
  • Nov 11, 2009
All you'll need to do in terms of timing cover/oil pan seating is trim the cork end gaskets to fit and put a bead of black rtv on the corners
banks
66
  • Nov 12, 2009
that is what i have done multiple times. seems to be working ok so far.
tyler, what kind of problems are you having getting it back on?
7upstang91
936
124
74
Florida
Nov 12, 2009
  • Nov 12, 2009
I couldnt get a couple bolts to line up then the guy for called to tow the Chevelle so everything dried now I have to start over.
Are you working or not?
banks
66
#10
  • Nov 16, 2009
  • #10
sorry man, i had to do stuff saturday morning and then get up to the dyno.
did you get everything finished up?
7upstang91
936
124
74
Florida
Nov 16, 2009
#11
  • Nov 16, 2009
  • #11
yeah I had everything finish Sunday night. I just need to fill it up tomorrow and change the oil.
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • dan50
  • Jul 18, 2026
dan50
