timing cover question
there is a difference between passenger cars and light trucks-if you look at the two, you'll be able to see the difference in the way the ports are cast. But, if the water pump bolts onto your timing cover, you should be ok.
the ones they advert in Jeg's and Summit are a universal type on which you can use a reverse direction pump or a standard pump...but for what either one of them charge, you can buy one off eBay that's brand new and probably get a water pump too!
If you go way back, (289's and before) the timing covers were indeed different, kind of like the 94-95 5.0 timing covers, but they spun the same as the crank, and they didn't use a backing plate behind the pump...the pump bolted directly to the timing cover.
