Timing Crank Gear?
I am currently building a new engine and during my preassembly while putting on the crank timing gear it seems exceptionally tight when sliding over the crankshaft key to the point where I would have to use a haramonic balancer installer with a metal tube to press it on. Does anyone have experience with this I understand that the key is the interference fit the with the gear but I'm not sure it should require this much effort. Once it is put on how would I take it off? I don't see how puller would fit around a chain without damaging it. Any suggestions?
You will find many of the aftermarket gears or balancers are tight and need some light snading or honing to make them fit, especially with the aftermarket cranks.
