Timing degrees adjustments
Don't worry about the timing adjuster at the dealership as long as you aren't going in for a problem that could be associated with it.
They may not like it but shouldn't give you too hard a time. They may not even know what it is.
Use the highest you can get, up to 93. Just listen for detonation (and retard timing if necessary), or track test for the best results (look for highest trap speed). You don't need anything else with the T/A.
